Firben
- 145
Two speakers A and B are separated by 1 meter, the point P is 4 m away from speaker B. If P is a person for what frequency does he hear that the intensity have a minimum?. (The listener hear that the sound intensity reduces and increases).I don't know the distance from P to B. (They form a right-angled triangle)
Estimate the relationship between the maximum and minimum intensity. Assume that there is a spherical wavepropogation and the effect from the surrounding kan be neglected. The speed of sound can be set to 340 m/s. The intensity decreases with 1/r^2 ie the intensity on the wave r m from the source is I0/r^2 where I0(zero) are the intensity on 1m from the distance from the source.
How can i found the intensity and what's about the max and min intensity, what value should i use for that ?
The distance from poit P to A is 4.123 m
I calculated the path difference to be 0.123 m
The answer should be I(max)/I(min) = ca 4400
