Evaluate lim e^x when x approaches zero from negative
In summary, when x approaches zero from the negative side, the function e^x is not continuous, but if x is approached from the positive side then the function is continuous.
Outrageous
374
What is the limit of e^x when x approaches zero from negative side
Taylor series? Then the answer is put all x= 0 , and the answer is 1, but why the question ask from negative side??
Thank you very much
Can you use that e^x is continuous? This would allow to use e^0.
If not, what do you know about the exponential function?
That is a strange question.
The question didn't say, but if it is continuous then I can use Taylor series for e^x . Then just substitute all x with zero? And get answer 1 . Then what is the point to have x approaches zero? Or should I use graph ?
Thank you
Thank you
What are the *definitions* of e and e^x that you are allowed to use? What facts about e^x are you allowed to use? The point is: how you deal with the problem depends crucially on what properties of e^x you know already. The question you present is almost meaningless, because you leave out so much important information.
It is not sufficient for a function to be continuous in order that it HAVE a Taylor series. But the Taylor series has nothing to do with the question.
Thank you
Do you understand what "continuous" means? The definition of "continuous" is that that the limit, as x goes to a, is equal to the value of the function, f(a). That is the point of "x approaches 0"- you evaluate the function at x= 0. If you meant to ask "why approach 0 from the negative side" there doesn't appear to be any special reason except perhaps to see if you really understood the idea of "limit". If f(x) is continuous at x= a (and e^x is continuous for all x), then, by definition, [itex]\lim_{x\to a} f(x)= f(a)[/itex], and, if the limit exists, [itex]\lim_{x\to a^-}f(x)= \lim_{x\to a^+} f(x)= \lim_{x\to a} f(x)[/itex].
Well e^x is differentiable therefore continuous at 0. So the limit at left of 0 is the same as the right of 0.
Thank you guys.
This is the whole question that I get from past year exam .
Evaluate lim e^x when x approaches zero from negative.
Thank you . I am too eager to solve problem until forget all the important basic knowledge.
Related to Evaluate lim e^x when x approaches zero from negative
1. What is the value of the limit of e^x as x approaches zero from the negative side?
The value of the limit of e^x as x approaches zero from the negative side is 1.
2. How do you evaluate the limit of e^x as x approaches zero from the negative side?
To evaluate the limit of e^x as x approaches zero from the negative side, you can use the rule that states that e^x is continuous everywhere and therefore the limit of e^x as x approaches a is equal to e^a.
3. Why is the value of the limit of e^x as x approaches zero from the negative side equal to 1?
The value of the limit of e^x as x approaches zero from the negative side is equal to 1 because e^x is an exponential function with a base of e, which is a constant value. Therefore, as x approaches zero from the negative side, the value of e^x will always approach 1.
4. Can you use the L'Hopital's rule to evaluate the limit of e^x as x approaches zero from the negative side?
Yes, you can use the L'Hopital's rule to evaluate the limit of e^x as x approaches zero from the negative side. The rule states that if the limit of f(x)/g(x) as x approaches a is in an indeterminate form (such as 0/0 or ∞/∞), then the limit is equal to the limit of the derivative of f(x) divided by the derivative of g(x).
5. How does the value of the limit of e^x as x approaches zero from the negative side differ from the value of the limit as x approaches zero from the positive side?
The value of the limit of e^x as x approaches zero from the negative side is the same as the value of the limit as x approaches zero from the positive side. This is because e^x is an even function, meaning that its graph is symmetrical about the y-axis. Therefore, as x approaches zero from both the negative and positive sides, the value of e^x will always approach 1.
