Expectation for # Exchanges (Quicksort Algorithm)
In summary, the conversation discussed the derivation of the complexity of quicksort, specifically the expectation for the number of exchanges. The formula for the expectation was shown to be (N/6) + (5/6N) by summing with respect to r and taking into account the probability of a key value being greater than the bound. The conversation ended with one participant asking for the original paper and the other providing a clarification on the derivation.
rwinston
36
Hi
I am reading Hoare's original paper where he derives the complexity of quicksort. I am trying to figure how he derives the expectation for the number of exchanges (sorry if this is a very CS-specific question):
Consider the situation at the end of the partition process, when the bound
was the rth key value in order of magnitude. As a result of the final
exchange, the item which yielded this key value will occupy the rth position
of the segment, and the r- 1 items with lesser key value will occupy the
r- 1 positions below it in the store. The number of exchanges made in the
course of the partition process is equal to the number of items which
originally occupied the r- 1 positions of the lower resulting segment, but
which were removed because they were found to have key values greater
than the bound. The probability of any key value being greater than the
bound is (N- r- I)[N, and therefore the expected number of such items
among the r- 1 items which originally occupied what was to be the lower
resulting segment is"
[tex]
\frac{(N-r-1)(r-1)}{N}
[/tex]
Summing with respect to r, dividing by N, and adding one for the final
exchange of the item which yielded the bound, we get the absolute
expectation of the number of exchanges:
[tex]\frac{N}{6}+\frac{5}{6N}[/tex]
I can't see how he derives the second equation, or what is involved in summing with respect to r.
Any CS grads out there who can help?
I didn't understand the same as you. I was working in "suming in respect to r" and trying to figure out what does it mean. I've tryed to sum from r=1 to N, but it doesn't work. And I haven't understand why he uses (N-r-1) and do not use (N-r), what I think is correct.
Did you find the answer for your question? If yes, please put it here or send to me at
leonardoguio@gmail.com
Please, send me the Hoare original paper too.
Thanks.
If you understand the number (n-r-1)/n as the propability of a given number to be bigger than the pivot and (r-1) the quantity of these given number that are in the wrong place, it's easy.
Sum in respect to r means that the number above consider that the pivot is in a given position r. But what position is this? The probability of the pivot to be the first number (and r=1) is 1/n, which is the same as the probability to the pivot be in any other position. So, in the middle case, we have to sum (n-r-1).(r-1)/n from 1 to n, which are the possible correct positions of the pivot, and then divide by n, because its a probability. After this, we have to sum 1 to the result, because it is the change of the pivot (to put the pivot in the correct position).
The result will be the number you typed above.
Below, consider thar every sum is from r=1 to n:
(1/n)[tex]\sum[/tex](n-r-1)(r-1) = (1/n)[tex]\sum[/tex](nr-n-r^2+1)= (1/n)[tex]\sum[/tex]nr - (1/n)[tex]\sum[/tex]n - (1/n)[tex]\sum[/tex](r^2) + (1/n)[tex]\sum[/tex]1 =(n+1)n/2 - n - (n+1)(2n+1)/6 + 1 = (n^2)/6 + (5/6) - n
Divide by n (probability) and sum 1 to the result (the exchange to put the pivot in the correct position) and we get:
n/6 + 5/6n
:biggrin:
Thanks Leonardo! That makes sense now :-)
FAQ: Expectation for # Exchanges (Quicksort Algorithm)
How does the Quicksort algorithm work?
The Quicksort algorithm is a sorting algorithm that follows the divide and conquer approach. It works by selecting a pivot element from the array and partitioning the other elements into two subarrays based on whether they are less than or greater than the pivot. This process is repeated recursively until the entire array is sorted.
How efficient is the Quicksort algorithm?
The Quicksort algorithm has an average-case time complexity of O(nlogn) and a worst-case time complexity of O(n^2). However, it is often considered one of the most efficient sorting algorithms due to its relatively low space complexity and its average-case performance.
What is the role of expectation for exchanges in the Quicksort algorithm?
The expectation for exchanges in the Quicksort algorithm refers to the expected number of exchanges (swaps) that will occur during the sorting process. This expectation is used to analyze the performance of the algorithm and make comparisons with other sorting algorithms.
Can the Quicksort algorithm handle duplicate elements?
Yes, the Quicksort algorithm can handle duplicate elements. However, if the pivot element is chosen poorly, it may result in an inefficient partitioning of the array and lead to a worst-case time complexity of O(n^2).
Are there any variations of the Quicksort algorithm?
Yes, there are several variations of the Quicksort algorithm, such as the randomized Quicksort, which uses a randomly chosen pivot element to reduce the likelihood of worst-case performance. Other variations include the three-way Quicksort, which handles arrays with many duplicate elements, and the dual-pivot Quicksort, which uses two pivot elements to improve performance on certain types of arrays.
