Explain the Inverse Function Theorem
In summary, the multi variable Inverse Function Theorem and the Implicit Function Theorem are important theorems in mathematics that deal with finding solutions to equations and inverting functions. The implicit function theorem states that the solution set of an equation is locally a function, while the inverse function theorem tells us when it is possible to locally invert a function. Both theorems have important applications in solving mathematical problems and understanding the properties of functions.
transphenomen
52
I am studying the multi variable Inverse Function Theorem and the Implicit Function Theorem. I think my brain is rebelling against understanding them and I would appreciate if someone here could explain the two theorems semi rigorously as well as explain when they are used, and why they are important.
Hi transphenomen!
Let me explain you the theorems by some examples.
The implicit function theorem states that the solution set of an equation is locally a function. For example, say that we need a function f such that
[tex]e^{xf(x)}+f(x)^3=0[/tex]
Does such a function even exist? We might solve the equation analytically, but this won't work in this case (I think). But we can use the implicit function theorem to say that there exists locally such a function (if some conditions on the derivatives are satisfied).
As can easily be seen, the point (0,-1) satisfies the equation
[tex]e^{xy}+y^3=0[/tex]
All we got to do is take the partial derivatives with respect to y, this gives us
[tex]xe^{xy}+3y^2[/tex]
So you see that the partial derivatives in (0,-1) don't vanish, so there exists a local function
[tex]g:]-\delta,\delta[\rightarrow ]-1-\epsilon,-1+\epsilon[[/tex]
such that g(0)=-1 and
[tex]e^{xg(x)}+g(x)^3=0[/tex]
For the inverse function theorem, it just tells us when it's ok to locally invert a funtion. For example, consider the function ex, can we invert this function? You might say yes: the logarithm is the inverse, but that's the definition of the logarithm, nobody tells us that this definition is a good one.
Now, we know that ex is a continuous function that never has a zero derivative. So by applying the inverse function theorem, we know that there is an inverse function f locally. Furthermore, we know it's derivative:
[tex](f^{-1})^\prime(e^a)=\frac{1}{e^a}[/tex]
thus
[tex](f^{-1})^\prime(x)=\frac{1}{x}[/tex]
In particular, this allows us to calculate the derivative of the logarithm without needing any property about the logarithm!
FAQ: Explain the Inverse Function Theorem
What is the Inverse Function Theorem?
The Inverse Function Theorem is a fundamental theorem in calculus that states that if a function is differentiable and has a non-zero derivative at a point, then it is locally invertible around that point.
What is the importance of the Inverse Function Theorem?
The Inverse Function Theorem is important because it allows us to find the inverse of a function and thus solve for the input (x) when given the output (y). This is useful in many mathematical and scientific applications.
How is the Inverse Function Theorem used in real-world problems?
The Inverse Function Theorem is used in real-world problems to solve for unknown variables in mathematical models and equations. It is also used in optimization problems, where finding the inverse of a function can help determine the maximum or minimum value of a given function.
What is the difference between the Inverse Function Theorem and the Implicit Function Theorem?
While both the Inverse Function Theorem and the Implicit Function Theorem deal with finding the inverse of a function, they are used in different situations. The Inverse Function Theorem is used when a function is explicitly given, while the Implicit Function Theorem is used when a function is not explicitly given and must be solved for using a set of equations.
What are the limitations of the Inverse Function Theorem?
The Inverse Function Theorem has limitations when the function is not differentiable or when the derivative is zero at a certain point. In these cases, the theorem cannot be applied and an alternative method must be used to find the inverse of the function.
