Exploring Limits: x^2sin(x)/1-cos^2(x)
  • Thread starter travwg33
  • Tags
    Limits
In summary, the conversation discusses a problem with the limit as x approaches 0 of (x^2sin(x))/(1-cos^2(x)). The speaker suggests simplifying the expression using the limit rule, but there is confusion about the answer being 0 or infinity. They also consider splitting the expression into x/sin(x) times x, but there is debate about whether this is correct or not. Ultimately, it is concluded that the limit is still 0.
travwg33
I seem to find a problem with the limit
lim(x->0)
(x^2sin(x))
1-cos^2(x)
using the limit as x approaches 0 of x over sine of x equals 1 we can simplify as such
(x) * (x) * sin(x)
sin(x) sin(x)
and this would equal 0
but what if we split it like:
x^2 * sin(x)
sin(x) sin(x)
then you get
x * x
sin(x)
which equals x and then infinity why is this different did i screw up on the second split?
x*x/sin(x)=(x/sin(x))*x. The first factor approaches 1. The second factor approaches 0. The limit is zero. Same conclusion. I don't know where you see the 'infinity'.
(x) * (x) * sin(x)
sin(x) sin(x)
is equivalent to
x * x
sin(x)
at this point in the second one, we would get zero over zero
using hopital's rule
we take the derivative of the top and then the bottom
giving us
2X/cos(x)
which the limit can be taken of easily
I think that is what you were asking for. right?
but what if we split the second function like the first into x over sin(x) times x and then use the limit rule i first referred to and then be just left with the x is there something wrong with doing that? It seems like there must bc it gives a whole different answer but why is doing that wrong
I really don't see why you think it gives a whole different answer. It's still 0, either way. Why do you think it isn't?
ok so with this split
x * x
sin(x)
without using hopital the
x term equals 1 and ur left with an x
sin(x)
x * x
sin(x)
sin(x)
Right. And x approaches 0, yes? The limit is still 0.
hhahaha wow now i feel like a tard yeah it does idk what my prob was there for some reason it was in my head that it was alim to infinity at the end of the problem
FAQ: Exploring Limits: x^2sin(x)/1-cos^2(x)
What is the limit of x^2sin(x)/1-cos^2(x) as x approaches 0?
The limit of x^2sin(x)/1-cos^2(x) as x approaches 0 is 0. This can be found by using L'Hopital's rule or by simplifying the expression and then substituting 0 for x.
How do you solve for the limit of x^2sin(x)/1-cos^2(x) as x approaches infinity?
To solve for the limit of x^2sin(x)/1-cos^2(x) as x approaches infinity, we can use the squeeze theorem. By setting upper and lower bounds for the expression, we can show that the limit is equal to 0 as x approaches infinity.
Is the limit of x^2sin(x)/1-cos^2(x) defined at x = pi?
No, the limit of x^2sin(x)/1-cos^2(x) is not defined at x = pi. This is because the denominator becomes 0 at this point, making the expression undefined.
Can the limit of x^2sin(x)/1-cos^2(x) be evaluated using the graph of the function?
Yes, the limit of x^2sin(x)/1-cos^2(x) can be evaluated using the graph of the function. By graphing the function and approaching the limit point, we can see that the function approaches 0.
How can the limit of x^2sin(x)/1-cos^2(x) be used in real-world applications?
The limit of x^2sin(x)/1-cos^2(x) can be used in physics, specifically in the study of oscillations and vibrations. This function can represent the displacement of a point on a vibrating string, and the limit can help determine the maximum displacement of the string.
