External Fields and Negative Energy Transitions In Dirac Particle
In summary, the problem at hand involves a positive energy spin-1/2 particle at rest, and an electrical field applied at t=0 that can be described by a vector potential. The goal is to show that there is a probability of finding the particle in a negative energy state at t>0, if those states are assumed to be originally empty. The final state can be an antiparticle at rest or with some energy, and perturbation theory must be used to calculate the probability. The specific cases of w>>mc^2 and w=mc^2 should also be considered and analyzed.
javiergra24
Suppose a relativistic particle with spin 1/2 at rest. Show that if we apply an electrical field at t=0 there's a probability fot t>0 of finding the particle in a negative energy state if such negative energy states are assumed to be originally empty.
Dirac equation at rest:
[tex]
(\boldsymbol{\hat{\beta}} mc^2) \psi (\mathbf{x},t) = i \hbar \frac{\partial\psi(\mathbf{x},t) }{\partial t}
[/tex]
Spinor solutions with positive energy for t<0
[tex]
$\Psi_{+}=\begin{pmatrix}
\psi^{(1)}\\ \psi^{(2)}
\end{pmatrix}={1\over\sqrt{V}}\begin{pmatrix}
1\\ 1\\ 0\\ 0
\end{pmatrix}e^{-imc^2t/\hbar}$\\
[/tex]
Applied electrical field and consecuent magnetic potential
[tex]
$\mathbf{E}=E_0 \cos(\omega t)\mathbf{u}_{x} \qquad \mathbf{A}=-\frac{E_0}{\omega} \sin(\omega t)\mathbf{u}_{x}$
[/tex]
I'm not sure how to solve this problem. Is it supposed that the particle at t>0 remains at rest? Or it has a negative energy E'?. First order perturbation theory must be used, but how about the final state of the particle?
Perturbed Hamiltonian should be
[tex]
$\displaystyle H'(t)=q c \boldsymbol{\hat{\alpha}} \mathbf{A}=q c\hat{\alpha}_{x}A_{x}$
[/tex]
Is it correct?
Thank you
The perturbed Hamiltonian acts on the spinor wavefunction. You'll need to use the Dirac matrices to write things in terms of the positive and negative energy components.
But the final state would be an antiparticle at rest? Or with some energy?
Oh I missed that the spinor is relativistic. A relativistic particle is not at rest, so neither the initial or final state are at rest.
Umm a relativistic particle can be at rest, with E=mc^2. The exact problem is:
"Consider a positive energy spin-1/2 particle at rest. Suppose that at t=0 we apply an external
(classical) vector potential (see mi first post)
which corresponds to an electric field of the form
Show that for there exists a finite probability of finding the particle in a negative energy state if
such negative energy states are assumed to be originally empty. In particular, work out quantitatively
the two cases: w>>mc^2 and w=mc^2 and and comment."
FAQ: External Fields and Negative Energy Transitions In Dirac Particle
What is an external field in relation to Dirac particles?
An external field is any type of force or potential that acts on a Dirac particle, such as an electric or magnetic field. These fields can affect the behavior and energy transitions of the particle.
What are negative energy transitions in Dirac particles?
Negative energy transitions in Dirac particles refer to a phenomenon where the energy of a particle changes to a negative value due to the influence of an external field. This is a unique aspect of Dirac particles and is not observed in other types of particles.
How do external fields affect the behavior of Dirac particles?
External fields can cause changes in the momentum and energy of Dirac particles, leading to changes in their behavior. These particles can also experience spin-flip transitions, where their direction of spin changes due to the influence of an external field.
What is the relationship between negative energy transitions and the Dirac equation?
The Dirac equation, which describes the behavior of Dirac particles, allows for the possibility of negative energy solutions. These solutions are necessary to explain the phenomenon of negative energy transitions in the presence of external fields.
How are negative energy transitions in Dirac particles observed in experiments?
Negative energy transitions in Dirac particles can be observed through various experimental techniques, such as scattering experiments or measurements of particle properties. These transitions can also be indirectly observed through their effects on the behavior of other particles in the system.
