Faraday's & Ampere's Laws: Conditions of Independence
In summary, Faraday's Law is independent of Ampere's Law only in the static case, but this is not always the case. If the loop subject to Faraday induction has a resistance much greater than its inductive reactance, then the induced voltage is simply -N dΦ/dt. However, if the loop current is not negligibly small, then the net flux through the loop includes both the externally applied flux and the flux set up by the loop current. In this case, the emf can be calculated as externally applied -dΦ/dt + L di/dt, where L is the loop self-inductance. This is due to the Law of Lenz, which states that the self-induced flux
atomicpedals
209
Under what conditions is Faraday’s Law independent of Ampere’s Law?
I want to say that this is so only in the static case, however this isn't right (or at least there's more to it). What am I missing?
If the filamentary loop subject to Faraday induction has a resistance much greater than its inductive reactance, then the induced voltage is simply ##-N d\phi / dt##. Otherwise, Ampere's Law comes into play, and the terminal voltage changes as the load current increases, should resistance fall below inductive reactance value.
Claude
emf = -N dΦ/dt is always true, irrespective of the loop current. Φ is the net flux thru the loop.
The thing is, if the loop current is not negligibly small then Φ is not just the externally applied flux but includes the flux set up by the loop current.
In the latter case, emf = externally applied -dΦ/dt + L di/dt
where i is the loop current
The direction of the self-induced flux is such as to oppose the rate of change of the externally applied flux.
Yes of course. I was treating ##"\phi"## as the external flux only. An external time varying flux is incident on a loop resulting in induction. If R is on the same order or less than inductive reactance ##L\omega##, then the loop internal flux due to its own current opposes the external flux per Law of Lenz. Then the emf measured at the terminals would be reduced by L di/dt as you stated.
I believe we agree. As long as ##\phi## is understood as the NET flux, superposition of external plus internal, then that value is fixed. I originally treated ##\phi## as the external flux only, which was my interpretation of the OP, which could have been wrong. But I agree with you that in the general case.
Claude
We do agree, and it's a bit of a fine point sometimes. I've seen a lot of stated problems that specify an external field, then ask for the current induced in a single loop. They don't state ignoring the self-inductance of the loop. Unfortunately, computing the self-inductance of a single loop is almost prohibitively difficult.
Of course, if you want to get really picky you also have to consider the effect of the loop's mag field on the source of the external field, resulting in a bona fide transformer problem. The stated problems usually avoid this by defining an external field.unaffected by the loop field.
FAQ: Faraday's & Ampere's Laws: Conditions of Independence
What is Faraday's Law of Induction?
Faraday's Law of Induction states that when there is a change in magnetic flux through a loop of wire, an electromotive force (EMF) is induced in the loop. This EMF can cause a current to flow in the loop if it is part of a complete circuit.
How is Faraday's Law applied in everyday life?
Faraday's Law has many practical applications, such as in generators used to produce electricity, transformers used to step up or down voltage, and electric motors used in appliances and vehicles. It also plays a key role in the functioning of devices like microphones and speakers.
What is Ampere's Law?
Ampere's Law is a fundamental law of electromagnetism that relates the magnetic field around a closed loop to the electric current passing through that loop. It states that the magnetic field is directly proportional to the current passing through the loop and the number of turns in the loop.
What is the significance of Ampere's Law in circuit analysis?
Ampere's Law is used in circuit analysis to determine the magnetic field strength and direction around a current-carrying wire or a group of wires. This information can then be used to calculate the force exerted on the wires or the induced EMF in nearby loops.
Are Faraday's Law and Ampere's Law independent of each other?
Yes, Faraday's Law and Ampere's Law are independent of each other. However, they are closely related and often used together to understand and analyze electromagnetic phenomena. Ampere's Law can be derived from Faraday's Law, and both laws are essential for understanding the behavior of electromagnetic waves.
