Find the Minimum length of the segment AB
In summary, the minimum length of the segment AB is achieved when the slope of the line intersecting (2,2) is equal to -1, and the corresponding equation is y=-x+4. This can be mathematically proven by constructing a function of the line passing through (2,2) and finding the arclength of AB in terms of the y-intercept. The critical point is found to be b=4, giving us the minimum value for the arclength. Therefore, the equation y=-x+4 is the desired equation for finding the minimum length of the segment AB.
dsb_101
A line through the point (2,2) cuts the x- and y- axes at points A and B respectively. Find the Minimum length of the segment AB.
Im really stuck on this problem. I know that minimum lengh is when f'>0.
Could you guys give me a lift off here?
ty
Just think about this geometrically. As the slope of the line intersecting (2,2) increases, negatively away from m=-1, then the length of the segment AB increases without bound. Likewise, as the slope of the line increases, positively from m=-1, to zero m->0, the length of the segment AB increases without bound. It is natural to assume that the slope which is some where half way between the two, is our choice- a good guess being m=-1. To see this mathematically let us construct a function of the line passing through the point (2,2). So we have y=mx+b passing through (2,2) and wish to find m and b such that AB is minimized. Let us first use the fact that our line passes through (2,2) so that we may write m in terms of b. 2=2m+b implying m=(2-b)/b. Therefore the equation is now refined, y=((2-b)/b)x+b. After all we want to study the behavior as b changes, which is of course B by definition, since b=y-intercept. Now let us find A, in terms of b. Well A is the x-intercept, therefore it is when y=0, or 0=((2-b)/b)x+b which implies x=2b/(b-2)=A. Now we know the points A and B in terms of b in our equation. This allows us to change values of b to study the behavior of the length AB. Now we know the equation of the line and its endpoints A, B---in terms of b. So let us find the arclength of AB in terms of b. S(b)=int(((2-b)/b)x+b,0,2b/b-2), where we have integrated from the x-value of B and the x-value of A. We get S(b)=b^2/(b-2). Now we have the length of the segment AB in terms b. So, we can "play around" with values of the y-intercept, b, to see what would happen to the length of the segment. We can verify our early assumptions by the taking the following limits: lim[(b^2/(b-2)), b, inf]=inf and lim[b^2/(b-2), b, 2]=inf . Now to finish the problem we simply differentiate S(b) to find the critical points. S'(b)=[b(b-4)/(b-2)^2], implying that b=4 is our critical point giving us our minimum value for S(b). Plugging this value of b back into our equation, y=-x+4 is our desired equation.
FAQ: Find the Minimum length of the segment AB
What is the definition of "segment AB"?
A segment is a part of a line that consists of two endpoints, A and B, and all the points on the line between those two endpoints.
Why is it important to find the minimum length of segment AB?
Finding the minimum length of segment AB is important in various fields such as mathematics, engineering, and physics. It helps determine the shortest distance between two points, which can be used to optimize designs, calculate velocities and accelerations, and solve problems involving shortest paths.
How can the minimum length of segment AB be calculated?
The minimum length of segment AB can be calculated using various mathematical methods, such as the Pythagorean theorem, the distance formula, or calculus. The method used will depend on the given information and the context of the problem.
Is there a way to find the minimum length of segment AB without using mathematical equations?
Yes, the minimum length of segment AB can also be determined visually by drawing a line segment between points A and B and measuring its length with a ruler or using a computer program with a measuring tool.
Can the minimum length of segment AB be negative?
No, the minimum length of segment AB is always a positive value. It represents the shortest distance between two points and cannot be negative.
