Find the order of the cyclic subgroup of D2n generated by r
In summary, the order of the cyclic subgroup of D2n generated by r is n, where n is the smallest positive integer for which r^n = 1. This subgroup contains the elements {1, r, r^2, ... , r^n-1} and has the same order as the generator r.
xsw001
37
Find the order of the cyclic subgroup of D2n generated by r.
The order of an element r is the smallest positive integer n such that r^n = 1.
Here is the representation of Dihedral group D2n = <r, s|r^n=s^2=1, rs=s^-1>
The elements that are in D2n = {1, r, r^2, ... , r^n-1, s, sr, sr^2, ... , s(r^n-1)}
Dihedral group is non-abelian (cannot commute), but cyclic group is abelian (can commute)
Okay it basically ask us to use the generator r from dihedral group to form a subgroup of D2n that is cyclic group.
So obviously we can't choose the term that has s(r^i) for i=1, ... , n-1 since it's not power of r.
that leaves us the set of choices {1, r, r^2, ... , r^n-1}, identity 1 has to be there and it commutes with all the elements in the group.
Since the order of D2n=2n, now the subgroup has half of its entries, and the property of D2n such that r^n=1, therefore the order of r is n. Does it implies that the order of cyclic subgroup {1, r, r^2, ... , r^n-1} of D2n is n then?
Yes, the order is n.
I'm not quite sure, but it's possible you are slightly mistaken. To be absolutely clear, you are asked to find not any cyclic group containing r, but to find the cyclic group generated by r. That is, [tex]<r> = \{ \ldots, r^{-2}, r^{-1}, 1=r^0, r^1, r^2, r^3, \ldots \}[/tex]. In a finite group we may simplify slightly to [tex]<r> = \{1, r, r^2, r^3, \ldots \}[/tex] because inverses are automatically included in this set.
In this particular case, by the relation r^n=1, we find that <r> = {1, r, r^2, ... r^n-1}, the order of which is n.
Related to Find the order of the cyclic subgroup of D2n generated by r
1. What does "Find the order of the cyclic subgroup of D2n generated by r" mean?
This means finding the number of elements in the subgroup that is generated by repeatedly applying the element r to itself in the dihedral group D2n.
2. How do you determine the order of a cyclic subgroup?
The order of a cyclic subgroup can be determined by finding the smallest positive integer k such that r^k = e, where e is the identity element.
3. What is the significance of the cyclic subgroup in D2n?
The cyclic subgroup generated by r is important because it represents the symmetries of a regular n-gon in the dihedral group D2n. It contains all the possible rotations and reflections that can be applied to the n-gon.
4. How do you find the elements of the cyclic subgroup generated by r?
To find the elements of the cyclic subgroup generated by r, you can repeatedly apply r to itself until you reach the identity element e. The elements will be r, r^2, r^3,..., r^(k-1), where k is the order of the subgroup.
5. Can the order of the cyclic subgroup generated by r be greater than n (the number of elements in D2n)?
No, the order of the cyclic subgroup cannot be greater than n. This is because the dihedral group D2n has n rotations and n reflections, so the maximum number of elements in a subgroup is n.
