Finding centripetal acceleration
In summary, the blade of a windshield wiper moves through an angle of 90 degrees in 0.28 seconds, covering a distance of 0.38pi meters. Using the formula v=d/t, the velocity of the tip of the blade is calculated to be (19/14)pi meters per second. Finally, using the formula A_{c}=v^2/r, the magnitude of the centripetal acceleration at the tip of the blade is found to be approximately 24 meters per second squared.
pinkerpikachu
29
1.The blade of a windshield wiper moves through an angle of 90 degrees in .28 . The tip of the blade moves on the arc of a circle that has a radius .76m. What is the magnitude of the centripetal acceleration at the tip of the blade.
2. Ac= v^2/r
3. okay, the accleration should equal r(theta)/t
but whenever I plug in my variables and solve I get an answer in the 7000s which is not reasonable at all.
The actual answer is 24 m/s^2 but I have no idea how to get there.
This is not correct. This expression would give you the linear velocity at the end of the wiper blade.
really? that is an equation my physics teacher and i derived together.
V = Δs/Δt = (rΔ(theta)/Δt)^2
then, plugging that into Ac
v^2/r = (rΔ(theta)/Δt)^2 / r = rΔ(theta)/Δt
Using [tex]A_{c}=\frac{v^{2}}{r}[/tex] It is clear you need to find the velocity since you already are given the radius.
I will assume that it is 0.28 seconds. The question states that it moves through an angle of 90o. Therefore, the distance the tip of the blade moves is 90o through a circle.
Using the circumference for a circle formula: [tex]C=2r\pi[/tex] where C=circumference, r=radius; This is the distance traveled around an entire circle, but we only want the distance covered in 0.25 of the circle.
Therefore, [tex]\frac{C}{4}=\frac{1}{2}\pi(0.76)[/tex]
The distance covered for the tip of the wiper is [tex]d=0.38\pi . m[/tex]
Using [tex]v=\frac{d}{t}[/tex] where v=velocity, d=distance (not displacement), t=time
Plugging in distance and time - [tex]v=\frac{0.38\pi}{0.28}[/tex]
[tex]v=\frac{19}{14}\pi . ms^{-1}[/tex]
Plugging back into the centripetal acceleration formula - [tex]A_{c}=\frac{(\frac{19}{14}\pi)^{2}}{0.76}[/tex]
Hence, [tex]A_{c}\approx24ms^{-2}[/tex]
Thanks! It seems simple once I get to look at all the work.
Now I just really wonder what my physics teacher was going on about...the equation certainly didn't get me the right answer.
v = 0.38pi/.28
...and this is the linear velovity, r(theta)/t, not the acceleration.
Here is where you are making an error...
you did not square the theta or the t
Well if you are looking for an equation that can find the centripetal acceleration straight from this kind of information given, then: (oh I will be skipping a few of the simpler steps since you seem more intelligent than I first suspected :smile:)
[tex]C=2r\pi[/tex]
Hence, [tex]d=\frac{C\Theta}{360}=\frac{r\pi\Theta}{180}[/tex]
Therefore, [tex]v=\frac{r\pi\Theta}{180t}[/tex]
Therefore, [tex]A_{c}=\frac{(\frac{r\pi\Theta}{180t})^{2}}{r}[/tex]
Finally, the equation you were looking for to plug and chug instantly is:
[tex]A_{c}=\frac{r(\pi\Theta)^{2}}{(180t)^{2}}[/tex]
where,
[tex]r =radius (metres)[/tex]
[tex]\Theta =Angle of turn (degrees)[/tex]
[tex]t =time (seconds)[/tex]
FAQ: Finding centripetal acceleration
What is centripetal acceleration?
Centripetal acceleration is the acceleration experienced by an object moving in a circular path. It is directed towards the center of the circle and is necessary to keep the object moving in a circular motion.
What is the formula for calculating centripetal acceleration?
The formula for calculating centripetal acceleration is a = v²/r, where a is the centripetal acceleration, v is the velocity of the object, and r is the radius of the circular path.
How does centripetal acceleration differ from regular acceleration?
Regular acceleration, or linear acceleration, occurs when an object's velocity changes in a straight line. Centripetal acceleration, on the other hand, occurs when an object's direction changes while maintaining a constant speed.
What are some real-life examples of centripetal acceleration?
Some examples of centripetal acceleration in everyday life include a car turning a corner, a satellite orbiting the Earth, and a rollercoaster moving around a loop.
How is centripetal acceleration related to centripetal force?
Centripetal acceleration is directly related to centripetal force, as it is the force that causes the acceleration towards the center of the circle. This force is necessary to keep an object moving in a circular path and is provided by a variety of factors such as tension, gravity, or friction.
