Finding charge of insulating sphere and conductor
In summary, the conversation discusses a figure with a configuration of a sphere, an outer ring, and an outermost ring. The given values for a, b, and c are 6.10 cm, 21.6 cm, and 26.6 cm respectively. The electric field at a point 11.5 cm from the center is 3.37x10^3 N/C radially inward, while the electric field at a point 58.6 cm from the center is 1.30x10^2 N/C radially outward. The conversation also mentions the equations k_e (Coulomb constant) = 8.99 x 10^9 Nm^2/C^2 and k_e
phanman
For the configuration shown in the figure below, suppose that a = 6.10 cm, b = 21.6 cm, and c = 26.6 cm. Furthermore, suppose that the electric field at a point 11.5 cm from the center is 3.37x10^3 N/C radially inward, while the electric field at a point 58.6 cm from the center is 1.30x10^2 N/C radially outward.I can't copy picture so i will describe it. In the middle there is a sphere with radius a, it is an insulator. There is an outer ring around this sphere which has radius b. Than the last ring is the outermost ring with radius c. The last ring is a conductor.
(a) find the charge of the insulating sphere
(b) the net charge on the hollow conducting sphere.
k_e(Coloumb constant) = 8.99 x 10^9 Nm^2/C^2
k_e(q/r^2)
What i did was since the second ring there is an electric field of 3.37x10^3N/C which is given, i calculated q using the equation about. Than the innermost sphere charge should be the opposite of that.
Hi phanman, welcome to PF.
There is no configuration "shown below." Without it, we cannot help you.
I would approach this problem by first understanding the setup and what is being asked. From the given information, it seems that there is a configuration of three concentric rings - an insulating sphere in the middle, an outer ring, and an outermost ring which is a conductor. The electric field at two points, 11.5 cm and 58.6 cm from the center, is also given.
To find the charge of the insulating sphere (a), we can use the equation for electric field, E = k_e(q/r^2). We know the electric field at a point 11.5 cm from the center is 3.37x10^3 N/C radially inward, so we can set up the equation as: 3.37x10^3 = (8.99x10^9)(q/11.5^2). Solving for q, we get the charge of the insulating sphere to be -2.37x10^-7 C (since the electric field is radially inward, the charge must be negative).
To find the net charge on the hollow conducting sphere (b), we can use the same equation, E = k_e(q/r^2), but using the electric field at a point 58.6 cm from the center, which is 1.30x10^2 N/C radially outward. Setting up the equation, we get: 1.30x10^2 = (8.99x10^9)(q/58.6^2). Solving for q, we get the net charge on the hollow conducting sphere to be 3.69x10^-6 C.
It's important to note that in this problem, we assume the outermost ring is a conductor, so the electric field is constant throughout the surface of the ring. If it was not specified, we would need more information to calculate the charge on the outermost ring. Overall, it's important to carefully read and understand the problem and use the correct equations and assumptions to find the solution.
FAQ: Finding charge of insulating sphere and conductor
How do I find the charge of an insulating sphere?
To find the charge of an insulating sphere, you will need to use the equation Q = k(4πε0)r2 where k is the Coulomb's constant, ε0 is the permittivity of free space, and r is the radius of the sphere. You will also need to know the electric field inside the sphere, which can be calculated using the equation E = kQ/r2. Once you have these values, you can solve for Q, which will give you the charge of the insulating sphere.
How do I find the charge of a conductor?
The charge of a conductor can be found using the equation Q = CV, where C is the capacitance of the conductor and V is the potential difference between the conductor and its surroundings. You will need to know the geometry of the conductor and the permittivity of the material it is made of to calculate the capacitance. The potential difference can be measured using a voltmeter.
Can an insulating sphere hold a charge?
Yes, an insulating sphere can hold a charge. The charge will be distributed evenly on the surface of the sphere and the electric field inside the sphere will be zero. This is because the charges on the surface of the insulating sphere will repel each other and spread out as far as possible, resulting in a uniform charge distribution.
How does the charge of an insulating sphere differ from a conductor?
The charge of an insulating sphere can only exist on the surface, while the charge of a conductor can also exist inside the material. Insulating spheres also have a lower capacitance compared to conductors, meaning they can hold less charge for the same potential difference. Additionally, the electric field inside an insulating sphere is zero, while the electric field inside a conductor is non-zero.
What is the purpose of finding the charge of an insulating sphere or conductor?
Knowing the charge of an insulating sphere or conductor is important in understanding their behavior in an electric field. It can also help in designing and analyzing electrical systems, such as capacitors and circuits. Additionally, it is a fundamental concept in the study of electrostatics and electromagnetism.
