Finding critical numbers of function with rational exponent
In summary, To find the critical numbers of the function F(x) = x^(4/5) (x - 4)^(2), you differentiated the function to get (1 / 5th root of x) (x - 4)(2x + 4/5(x-4)), but you are unsure how to simplify this expression to solve for the critical values of x. To find the critical values, set F'(x) = 0 and solve for x by setting each factor equal to zero.
TsAmE
132
Find the critical numbers of the function:
None.
I differentiated and got to (1 / 5th root of x) (x - 4)(2x + 4/5(x-4))
but I don't know how I can simplify the expression to be able to solve for the critical values of x
None.
You're almost there. What values of x make F'(x) = 0? You have three factors, so for F'(x) to be zero, at least one of the factors must be zero.
FAQ: Finding critical numbers of function with rational exponent
What is a critical number of a function with rational exponent?
A critical number of a function with rational exponent is a value of x where the derivative of the function is equal to zero or undefined.
How do you find the critical numbers of a function with rational exponent?
To find the critical numbers of a function with rational exponent, you must first take the derivative of the function. Then, set the derivative equal to zero and solve for x. The resulting values of x are the critical numbers of the function.
Why are critical numbers important in functions with rational exponent?
Critical numbers are important in functions with rational exponent because they indicate where the function has a local maximum or minimum. This information is useful in understanding the behavior of the function and can be used to optimize the function.
Can a function with rational exponent have more than one critical number?
Yes, a function with rational exponent can have more than one critical number. This can happen when the derivative of the function has multiple solutions for x, resulting in multiple critical numbers.
Are critical numbers the same as inflection points in a function with rational exponent?
No, critical numbers and inflection points are not the same in a function with rational exponent. Inflection points occur where the concavity of the function changes, while critical numbers indicate where the derivative is zero or undefined.
