Albert1
- 1,221
$m,n \in N$
satisfying :
$\sqrt {m+2007}+\sqrt {m-325}=n $
find Max(n)
satisfying :
find Max(n)
Very neat! (Clapping)kaliprasad said:we have
(m+ 2007) – (m- 325) = 2332 ..1
√(m+2007)+√(m−325) = n ..(2) given
Dividing (2) by (1) we get
√(m+2007)-√(m−325) = 2332/n … (3)
And (2) and (3) to get 2 √(m+2007) = n + 2332/n
Now RHS has to be even so n is even factor of 2332/2 or 1166 hence largest n = 1166.
Albert said:now ,find min(n)=?
$2332=a^2+2ua=a(2u+a)=a\times n=2\times 1166=22\times 2\times53=22\times 106$Albert said:let :
$u^2=m-325-------(1)$
$(u+a)^2=m+2007-------(2)$
$(2)-(1):2332=a^2+2ua-----(3)$ (so a must be even)
max(n) must happen while a=2,so from (3) we have u=582
so max(n)=582+584=1166
The purpose of this expression is to find the maximum value of n that satisfies the given equation, where m and n are both natural numbers.
This notation means that both m and n are natural numbers, also known as positive integers. This is important to note when solving the equation, as it restricts the possible values of m and n.
To solve this equation, you can first isolate one of the square roots by subtracting it from both sides. Then, square both sides of the equation to eliminate the remaining square root. This will leave you with a quadratic equation that can be solved using standard methods.
Yes, there are typically multiple solutions to this equation. The number of solutions will depend on the values of m and n, and can be determined by solving the quadratic equation that results from isolating the square root terms.
No, this equation cannot be solved without using some form of algebra. Since it contains square root terms, it cannot be solved using basic arithmetic operations alone. Algebraic manipulation is necessary to isolate the variable and solve for its value.
