Finding the Centre and Intersection of Circle X2 + y2 + 4x – 16y + 18 = 0
In summary, the homework statement is trying to find the intersection of a circle with a square. The Attempt at a Solution found that the intersection is at (x + 2) ^2 + (y – 8) ^2 = 50.
Rubydeemer
Find the centre of circle X2 + y2 + 4x – 16y + 18 = 0, show it's radius is 5√2 and find the co-ordinates where it is intersected by y = 3x - 6
by completing the square using X2 + 2px = (x + p) 2 – p2
X^2 + y^2 + 4x – 16y + 18 = 0
Substituting p for 2 we get;
X^2 + 4x = (x + 2) ^2 – 2^2 = (x + 2) ^2 – 4
Substituting p for -8 we get;
y^2 -16y = (y – 8) ^2 – (-8)^2 = (y – 8) ^2 – 64
Collecting the completed-square forms gives;
(x + 2) ^2 – 4 + (y – 8)^ 2 – 64 + 18 = 0
Collecting and rearranging gives;
Comparing this to the form (x-a) ^2 + (y-b) ^2 = r^2 we can see that a = 2 and b = 8. The radius = √50 = 7.071067812.
√50 = 7.071067812.
√2 = 1.414213562 * 5 = 7.071067812.
To find the intersection I tried using substitution but have got myself confused.
(x + 2) ^2 + (y – 8) ^2 = 50, y = 3x - 6
(x + 2) ^2 + (3x – 14) ^2 = 50
4x^2 - 80x + 150 = 0
Now I can't work out how to factorise the above to gain an answer for X and so for Y also as co-ordinates.
I'm guessing that the line doesn't intersect the circle and but thought I should be able to take the calculation further to prove it, rather than relying on myself not being able to do it.
I would really appreciate any pointers as to where my mistake(s) might be. I am doing an adult ed course so please don't give me the answer.
thanks for reading.
Two things:
1. You should have been able to show that
[tex]\sqrt {50} = 5\sqrt 2 [/tex] without a calculator. Try to do prime factorization to get
[tex]\sqrt {50} = \sqrt {5 \cdot 5 \cdot 2} = \sqrt {{5^2} \cdot 2} = 5\sqrt 2 [/tex]
2. On your last line, it is not supposed to be 2x^2, check your arithmetic. Also, just because you do not know how to factor it, doesn't mean there is no solution. You may have to use the quadratic formula. Of course, there could be both real and imaginary roots(for a total of two).
Cases:
1. Two real roots: the line would intersect the circle at two points
2. One real root, one imaginary root: the line would intersect the circle at one point(it would be tangent to the circle)
3. Two imaginary roots: the line will NOT intersect the circle.
Thanks Pinu7, I had tried it with quadratic formula and got x = 1734 and x = 1254 so thought I was way off.
I'll try again.
On your other point "On your last line, it is not supposed to be 2x^2, check your arithmetic" did you mean 4x^2?
thanks again.
I'll try again.
thanks again.
Yes, it's not supposed to be 4x^2. What is it supposed to be? Be careful expanding (3x-14)^2. If you get it right, it factors easily.
FAQ: Finding the Centre and Intersection of Circle X2 + y2 + 4x – 16y + 18 = 0
What is the equation for finding the centre and intersection of a circle?
The equation for finding the centre and intersection of a circle is x2 + y2 + 4x – 16y + 18 = 0.
How do you determine the centre of a circle from the equation?
To determine the centre of a circle from the equation, you need to complete the square for both the x and y terms. This will give you the equation in the form (x - h)2 + (y - k)2 = r2, where (h, k) is the centre of the circle and r is the radius.
What is the significance of the number added to the x and y terms in the equation?
The number added to the x and y terms in the equation is used to determine the centre of the circle. It is important to note that the x and y terms must be in the form of (x - h)2 and (y - k)2 for the equation to represent a circle.
How do you find the intersection points of a circle with other equations?
To find the intersection points of a circle with other equations, you need to substitute the x and y values from the equation of the circle into the other equation. This will give you a quadratic equation which can be solved to find the intersection points.
Can the equation for finding the centre and intersection of a circle be used for any type of circle?
Yes, the equation for finding the centre and intersection of a circle can be used for any type of circle, as long as the x and y terms are in the form of (x - h)2 and (y - k)2, respectively. This includes circles with a centre at the origin or shifted from the origin, as well as circles with a radius greater than or less than 1.
