Finding the difference of two series?
In summary, the sum A is equal to $\frac{\pi^2}{12}$, which can be found by taking the difference between S and A and expressing it in terms of S.
shamieh
539
\(\displaystyle A = 1 - \frac{1}{2^2} + \frac{1}{3^2} - \frac{1}{4^2} + \frac{1}{5^2}\)...
So I know this is the series \(\displaystyle \sum^{\infty}_{n = 1} \frac{(-1)^n}{n^2}\)
Then I'm given
\(\displaystyle S =1 + \frac{1}{2^2} + \frac{1}{3^2} + \frac{1}{4^2} + \frac{1}{5^2}\)...
And I know that this is obviously the series \(\displaystyle \sum^{\infty}_{n = 1} \frac{1}{n^2}\)
Question: Given that \(\displaystyle S = \frac{\pi^2}{6}\) find the sum A given above. (Hint: consider S - A and express it in terms of S)
So I think I know the answer to this but I'm not sure and might need some guidance...But if both of these series are convergent since the alternating series is convergent by using the absolute value test and the original 1/n^2 is convergent by p series, if we were to take S - A wouldn't we get every other term remaining , while every other term canceled ? Like for example
\(\displaystyle S - A\)
\(\displaystyle S = 1 + 1/2^2 \)
\(\displaystyle A = 1 - 1/2^2 \)
So the second terms would cancel right? and the first term sum would be 2.. but every odd\(\displaystyle ^{th} \)term seems to remain as it will double since both signs are positive... How would I do this?
Then I'm given
It is easy to see that $\displaystyle A = S - 2\ \frac{S}{2^{2}} = \frac{S}{2}$...
Kind regards
$\chi$ $\sigma$
Then I'm given
$\displaystyle \begin{align*} S &= \frac{1}{1^2} + \frac{1}{2^2} + \frac{1}{3^2} + \frac{1}{4^2} + \frac{1}{5^2} + \frac{1}{6^2} + \dots \\ S &= \frac{1}{1^2} + \frac{1}{3^2} + \frac{1}{5^2} + \dots + \frac{1}{2^2} + \frac{1}{4^2} + \frac{1}{6^2} + \dots \\ S &= \frac{1}{1^2} - \frac{1}{2^2} + \frac{1}{3^2} - \frac{1}{4^2} + \frac{1}{5^2} - \frac{1}{6^2} + \dots + \frac{1}{2^2} + \frac{1}{4^2} + \frac{1}{6^2} + \dots + \frac{1}{2^2} + \frac{1}{4^2} + \frac{1}{6^2} + \dots \\ S &= A + 2\left( \frac{1}{2^2} + \frac{1}{4^2} + \frac{1}{6^2} + \dots \right) \\ S &= A + 2 \left[ \frac{1}{ \left( 2 \cdot 1 \right) ^2} + \frac{1}{ \left( 2 \cdot 2 \right) ^2 } + \frac{1}{ \left( 2 \cdot 3 \right) ^2 } + \dots \right] \\ S &= A + 2 \left[ \frac{1}{4} \left( \frac{1}{1^2} \right) + \frac{1}{4} \left( \frac{1}{2^2} \right) + \frac{1}{4} \left( \frac{1}{3^2} \right) + \dots \right] \\ S &= A + \frac{1}{2} \left( \frac{1}{1^2} + \frac{1}{2^2} + \frac{1}{3^2} + \dots \right) \\ S &= A + \frac{1}{2}S \\ A &= \frac{1}{2} S \\ A &= \frac{1}{2} \left( \frac{\pi ^2}{6} \right) \\ A &= \frac{ \pi ^2 }{12} \end{align*}$
FAQ: Finding the difference of two series?
What is the difference between a series and a sequence?
A series is a sum of the terms in a sequence, while a sequence is a list of numbers in a particular order.
How do you find the difference between two series?
To find the difference between two series, subtract the terms in one series from the corresponding terms in the other series.
What is the significance of finding the difference between two series?
Finding the difference between two series can help identify patterns or trends in the data, and can also be used to measure the change or growth between the two series.
What is the mathematical notation for finding the difference between two series?
The mathematical notation for finding the difference between two series is written as (an - bn), where an and bn are the terms in the two series.
Can the difference between two series be negative?
Yes, the difference between two series can be negative if the terms in the second series are larger than the corresponding terms in the first series.
