Finding the Indefinite Integral Extension Questions
In summary: You don't have to use the formula you wrote above, but you can if you want.In summary, to solve the given integral, the u-substitution method can be used by letting u=cos(x^4+4) and du=(-4x^3)sin(x^4+4)dx. This results in the integral becoming C \int e^{-u}du, where C is a numerical constant.
CaptainK
∫8x3e-cos(x4+4)sin(x4+4)dx
Let u = cos(x4+4)
I know the answer does not have the sin in it and only the e remains, because when the integral is found e stays unchanged.
I could find somewhere online to calculate it, but I want to know how to do it, because questions like this will be on the final exam.
Let u = cos(x4+4)
You have the correct u substitution. Now use it. What's du?
So, what do you get after that u substitution??
So I've found du and put it into the form
∫udv = uv - ∫vdu
so for v I have 8x3
du = -sin(4x3) dx
dv = 24x2 dx
Which gives me
∫cos(x4+4)24x2dx = cos(x4+4)8x3 - ∫8x3(-sin4x3) dx
But I feel like I'm going down the wrong path, especially since the e isn't present
You are going down the integration by parts path. It's not the right way to go. Why do you think du=(-sin(4x^3))dx?
So using substitution
du = sin(x4+4)
because cos converted to sin doesn't change its sign, I thought it did but its for converting from cos to sin.
t = u
∫f'(g(x))g'(x) dx = ∫f'(t) dt/dx = ∫ f'(t)dt = f(t) + C
= f(g(x)) + C when substituting back in
f(x) = original equation and
t = u = cos(x4+4)
du = sin(x4+4)
t = u
t = u = cos(x4+4)
df(x)=f'(x)*dx. f(x) here is cos(x^4+4). What is df(x)?
so f(x) = cos(x4+4)
then
f'(x) = sin(x4+4) + 4x3
which gives
∫cos(x4+4) +4x3 *sin(x4+4) + C
CaptainK said:
so f(x) = cos(x4+4)
then
which gives
I'd suggest you review the chain rule. If f(x)=cos(x^4+4) then the derivative f'(x) is not what you wrote. Give it another try. Tell me what the chain rule says.
Chain Rule states
dy/dx = dy/du * dx/du
8∫x3∫e-cos(x4+4)∫sin(x4+4)
8∫x4/4∫e-cos(x4+4)∫cos(x4+4)+4x3
CaptainK said:
Chain Rule states
Stop worrying about the integral for a while. You are having trouble differentiating f(x)=cos(x^4+4). Try and get that right first.
Finding the derivative of cos(x4+4)
I got -4x3sin(x4+4)
Do I then follow the formula above with f(x) and t and then solve for the Integral.
I got -4x3sin(x4+4)
Ok, you've got the derivative. If you take u=cos(x^4+4), that means du=(-4x^3)sin(x^4+4)dx. Now you should be able to turn the integral into
[tex]C \int e^{-u}du[/tex]
where C is a numerical constant. This is u-substitution.
FAQ: Finding the Indefinite Integral Extension Questions
What is an indefinite integral?
An indefinite integral is a mathematical operation that represents the antiderivative of a given function. It is used to find the original function whose derivative is equal to the given function.
What is the process for finding an indefinite integral?
The process for finding an indefinite integral involves using integration techniques, such as substitution, integration by parts, or trigonometric substitution, to evaluate the integral. The result will be a function plus a constant, as the exact value of the constant cannot be determined without additional information.
How is an indefinite integral different from a definite integral?
An indefinite integral does not have specific limits of integration, whereas a definite integral has upper and lower limits that determine the specific interval over which the integration is performed. This means that an indefinite integral will result in a function, while a definite integral will result in a numerical value.
Why is finding the indefinite integral important?
Finding the indefinite integral allows us to solve a variety of problems in mathematics, physics, and engineering. It is also a fundamental concept in calculus and is used to find areas under curves, volumes of solids, and many other important quantities in real-world applications.
What are some common mistakes when finding the indefinite integral?
Some common mistakes when finding the indefinite integral include forgetting to include the constant of integration, using incorrect integration techniques, or making algebraic errors. It is important to carefully check the final result for any potential mistakes and to practice regularly to improve proficiency in integration.
