VictorQ
- 1
Hi guys.
Electrical engineering student here trying to get some real physics under his skin.
I'm trying to derive the field and ultimately the inductance of a finite solenoid based on the spiral shape of the windings (because I assume - for no good reason - that the exact geometry is somehow significant).
Parameters: N number of turns, l length of coil, R0 radius of coil, I current in coil.
Assumptions: Lossless coil, static field (no displacement current).
Ampere's law : [tex]\nabla^2 A = -\mu J[/tex]
Parametric description of J(z) in cylindrical coordinates:
[tex] J(r,\theta,z) = I \cdot \frac{\delta(r-R0) \cdot \delta(\theta-N/l \cdot 2 \pi \cdot z ) } {\sqrt{1+l^2/N^2}} \cdot \left[ {1 , N/l \cdot 2 \pi \cdot z + \pi/2, l/N}\right][/tex]
where I is the current, and the bracket on the right is a vector in cyl. coords., where the scalar factors obviously do not multiply the angle component...
Direct numerical integration of Biot-Savart's law did draw me a pretty picture of the H-field, but it seems to be an inefficient approach to calculating the impedance. It simply takes longer than I want to wait.
More promising: I managed to transform the current distribution vector field onto a cylindrical Fourier-space inspired by http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.152.9411&rep=rep1&type=pdf". The transform I used is the polar transform described in the paper with a combined Fourier-series/BesselJ transform in the angular and radial directions respectively. I then tacked on a regular Fourier transform in the z-direction.
This diagonalized the Laplacian nicely and then gives me the transform of the vector potential. I can't manage the inverse transform, though, symbolically or numerically. Maple thought about it for about an hour before giving up completely...
The inductance can be written in terms of the vector potential, and via Stoke's theorem can be written as:
[tex]L=\frac{1}{I} \oint_C A \bullet d\vec{r} [/tex]
where the curve C is up along the spiral and then directly down to the origin, nicely framing the flux linkage area of each turn.
I would like to calculate the inductance in the Fourier-domain directly, but how on Earth do I go about transforming the path integral?
Writing it in terms of anti-derivatives allows me to easily transform the functions, but what should the limits of integration (z=[0;l]) be in the transform domain (w=[0;1/l] obviously doesn't work as it does not evaluate to a numerical value)?
I feel like I'm SO close, but it just might not be possible at all (?).
Thanks so much!
