Fluids: Conservation of Momentum
In summary: ChauhanIn summary, the derivation of the Navier Stokes equation involves the conservation of momentum through a control volume (CV). This is represented by the equation Time rate of Momentum Change in CV = Time rate of Momentum Change into CV - Time rate of Momentum Change Out of CV + Sum of External Forces. The inclusion of the Sum of External Forces accounts for forces acting on the boundary of the control volume, such as viscous stresses and pressure, as well as body forces like gravity. This expression is equivalent to Newton's second law, where the sum of the external forces on the control volume must equal the mass times acceleration.
yosimba2000
206
Ok, so for the derivation of the Navier Stokes, the conservation of momentum through a control volume (CV) is
Why is Sum of External forces in there? I know that Time rate of Momentum Change is dp/dt and represents force, so the equation is pretty much saying
force inside = force in - force out
But why are these external forces not already counted for in the Momentum Changes into and out of the CV? What is the intuition behind including the External Forces? Also, why is it a + Sum of External Forces and not
-Sum of External Forces?
It is referring to the forces acting on the boundary of the control volume like viscous stresses and pressure; also body forces, like gravity, acting on the contents of the control volume.
The complete expression Time rate of Momentum Change in CV - Rate of Momentum Entering CV+Rate of Momentum Leaving CV is just your Ma from Newton's 2nd Law. Ma must equal the sum of the external forces on the control volume.
Chet
FAQ: Fluids: Conservation of Momentum
What is the law of conservation of momentum?
The law of conservation of momentum states that in a closed system, the total momentum remains constant. This means that the total momentum before a collision or interaction is equal to the total momentum after the collision or interaction.
How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. The equation for momentum is: p = mv, where p is momentum, m is mass, and v is velocity.
How does conservation of momentum apply to fluids?
In fluids, the law of conservation of momentum applies to the total momentum of the fluid particles. This means that if there is no external force acting on the fluid, the total momentum of the fluid particles will remain constant.
What is an example of conservation of momentum in fluids?
One example of conservation of momentum in fluids is when two objects of different masses collide in a fluid. The total momentum before the collision will be equal to the total momentum after the collision, as long as there are no external forces acting on the system.
How does conservation of momentum relate to fluid dynamics?
Conservation of momentum is an important principle in fluid dynamics because it helps explain the behavior of fluids in motion. It allows us to predict how fluids will move and interact with each other, and is essential in understanding phenomena such as fluid flow, turbulence, and wave motion.
