Force, Friction, Feel like I am not given sufficient info
In summary, the conversation discusses the problem of a loaded railroad car with a coefficient of static friction of 0.25 and a speed of 48 km/h. The question is to determine the shortest distance the train can be stopped without causing the crates to slide, using constant acceleration. The conversation also touches on the issue of mass not being a factor in the calculation, and discusses two methods for solving the problem. Ultimately, the conclusion is that mass does not affect the outcome of the problem.
1MileCrash
1,342
41
The floor of a railroad car is loaded with loose crates, having a coefficient of static friction of 0.25 with the floor. If the train is initially moving at a speed of 48 km/h, in how short of a distance can the train be stopped without causing the crates to slide? (constant acceleration.)
I've worked the entirety of this chapter's problems and this is literally number 5 out of ten dozen. Can someone explain to me how I am supposed to go about this without mass or a normal force? I don't know what to do with just a coefficient of static friction..
Method #1. Since you are not given the mass of the crate(s), it clearly doesn't matter - so assume a nice convenient figure like 14 kg. [I always like any assumed mass to be even, so that fractions are not introduced when you calculate Kinetic Energy. 2 x 7 is good, since 7 is a prime number so you are not likely to get an incorrect answer by co-incidence. [note that 2+2 = 2x2 so you can get the correct answer by coincidence when working with just a 2]
As you go through the problem you will find you alternately multiply and divide by this mass showing it didn't matter what value you chose.
Method #2. Let the mass of the crate(s) be M. As you work through the problem you will find that M cancels out - so you will get a "number only" answer in the end.
I got it, I just called normal force mg, so acceleration needed to overcome max static friction was equal to ug.
Seems like weight matters in this case though. Wouldn't those crates be less likely to slide if I put 500kg of mass in them?
I might seem like the mas mattered, but your physics calculation just showed it doesn't. have faith! Trust the Force [calculation] Luke!
I understand your frustration with not having all the necessary information to solve a problem. However, it is important to remember that in real-life situations, we often do not have all the information we would like. In this case, we are given the coefficient of static friction, which is a measure of the force required to keep an object from sliding on a surface. We can use this information along with the initial speed of the train to calculate the deceleration needed to stop the train without causing the crates to slide.
To solve this problem, we can use the equation for Newton's second law of motion, which states that force equals mass times acceleration (F=ma). In this case, the force we are interested in is the force of friction between the crates and the floor, which can be calculated by multiplying the coefficient of static friction by the normal force (Fn). Since the normal force is equal to the weight of the crates, we can use the mass of the crates to calculate Fn.
Once we have the force of friction, we can use it in the equation for Newton's second law to solve for the acceleration needed to stop the train. From there, we can use the equation for constant acceleration (v^2 = u^2 + 2as) to calculate the distance required to stop the train.
In conclusion, while it may seem challenging to solve a problem with limited information, as scientists, it is our job to use the information we do have to make educated calculations and predictions. In this case, we can use the coefficient of static friction and the initial speed of the train to solve for the necessary distance to stop the train without causing the crates to slide.
FAQ: Force, Friction, Feel like I am not given sufficient info
What is force?
Force is a physical quantity that is used to measure the interaction between two objects. It can be described as a push or pull that can cause an object to accelerate, decelerate, or change direction.
How is force measured?
Force is measured using a unit called Newton (N). To measure the force acting on an object, you need to multiply its mass (in kilograms) by its acceleration (in meters per second squared). 1 Newton is equal to 1 kilogram-meter per second squared (kg•m/s²).
What is friction?
Friction is a force that opposes the motion of objects that are in contact with each other. It is caused by the roughness of surfaces and the interlocking of microscopic ridges and valleys. Friction can either slow down or stop the motion of objects.
How does friction affect an object's motion?
Friction can either increase or decrease an object's motion. When two surfaces are rough, the frictional force between them is greater, which can slow down the object's motion. However, when two surfaces are smooth, the frictional force is lesser, allowing the object to move more easily.
Why is it important to consider friction in scientific experiments?
Friction plays a crucial role in scientific experiments as it can affect the accuracy and precision of the results. By understanding and accounting for friction, scientists can make more accurate predictions and conclusions about the behavior of objects and systems.
