Force on object located between two liquids
In summary, the pressure at the lower end is 15cm/s and the speed of water is 15cm/s when it exits the pipe at a horizontal distance of 0.3m from the pipe outlet.
songoku
2,368
349
A cube has side as shown. If the atmospheric pressure is p, find the force acting at the bottom of the cube!
P = F / A
P = ρ.g.h
Fbottom = Pbottom . A
= (p + Pressure by upper liquid + P by lower liquid) . 4/9 b^2
= (p + Pressure by upper liquid + d.g.1/3 b). 4/9 b^2
I don't understand how to find the pressure by upper liquid. I guess I have to use P = ρ.g.h but I don't know what the 'h' is.
By definition, h is depth so we measure the depth from the surface, but we don't know how deep is the cube from the upper liquid surface.
I think I'm missing something...
P = F / A
P = ρ.g.h
I'm not sure but can't we use buoyant force? viz = weight of liquid displaced ...
I don't know. As far as I understand, bouyant force is the difference between the force acting on the bottom and the force acting on the top of the object; and the question is asking only about the force on the bottom.
btw, what is viz?
Do a Google search for "Object floating in two liquids". I think the key to this problem is to find the density of the object and you can do that if you know the density of the two fluids and the distance submerged in both liquids (which happens to be the same distance).
Then Fboyobj*g*voldisplaced and you know the dimensions of the cube
density of object = 1/2 D + 1/2 d
I don't understand this :
I think the density should the the density of liquid, not object.
Fboy = ρliquid.g.Vimmersed; because therea re 2 liquids, I think there are 2 bouyant forces
Fboy = D.g.4/27 b3 + d.g.4/27 b3
I am not sure I found the bouyant correctly, and also how to find the force acting at the bottom part after finding bouyant force?
Another question, how to take atmospheric pressure into account?
Thanks
My error, it should be ρLiq. I think your answer is correct. I think you can neglect the atmospheric pressure component because the density of air is so much less than the density of the fluids.
One thing is troubling me ... what will be the direction of buoyant force ?
They will depend on the densities of the liquids and block (maybe) ... Do we know that ?
Sorry I didn't give the choices for this question.
a. [tex]b^3 [(D+d)g + \frac{p}{b}][/tex]
b. [tex]\frac{4}{27}b^3 [(3D + d)g + \frac{3p}{b}][/tex]
c. [tex]b^3 [(D - d)g + \frac{3p}{b}][/tex]
d. [tex]\frac{4}{27}b^3[(3D-d)g+\frac{3p}{b}][/tex]
e. [tex]\frac{4}{27}b^3[(D+d)g+\frac{p}{b}][/tex]Good question cupid, taking the consideration that some of the choices contain negative sign. It means that we should know the direction of the bouyant force; which I don't know...:(
Looking from the choices again, we should take atmospheric pressure into account.
Another question, is bouyant force the same as force acting on the bottom of the cube?
Thanks
I think the direction of bouyant force is still upwards. Half of it is immersed in D and half is in d. Both will produce bouyant forces and both are upwards.
But I still don't know how to find the pressure on the bottom...any help please?
A section of the pipe with an internal diameter of 10cm tapers to an inner diameter of
6cm as it rises through a height of 1.7m at an angle of 60o with respect to horizontal.
The pipe carries water and its higher end is open to air. (a) If the speed of the water at
the lower end is 15cm/s what are the pressure at the lower end and speed of water as
its exits. (b) If the higher end of the pipe is 0.3m above the ground at what horizontal
distance from the pipe outlet does the water land.
I don't understand the relation of your post with the question I posted. Are you asking an entirely new question?
FAQ: Force on object located between two liquids
What is the force acting on an object located between two liquids?
The force acting on an object located between two liquids is called buoyant force. This force is caused by the difference in pressure exerted by the two liquids on the object.
How is the buoyant force calculated?
The buoyant force is calculated by multiplying the density of the liquid, the acceleration due to gravity, and the volume of the object submerged in the liquid. It can be expressed as Fb = ρVg, where ρ is the density, V is the volume, and g is the acceleration due to gravity.
What factors affect the buoyant force on an object?
The buoyant force on an object is affected by the density of the liquid, the volume of the object submerged, and the acceleration due to gravity. The shape and size of the object can also impact the buoyant force.
How does the position of an object between two liquids affect the force on it?
The position of an object between two liquids can affect the force on it by changing the amount of liquid that is pushing against it. If the object is closer to the denser liquid, it will experience a stronger buoyant force.
What happens to the buoyant force if the two liquids have the same density?
If the two liquids have the same density, the buoyant force on an object located between them will be zero. This is because the pressure exerted by the two liquids will be equal, resulting in a balanced force on the object.
