Force, pressure and acceleration
In summary, the thin pin had a greater pressure and was able to create more motion than the thicker pin.
quark001
44
Our high school physics course recently covered pressure. I invented the following scenario to illustrate something I don't understand about pressure.
Say you have 2 thumbtacks/pins. They have the same mass. You press each pin to a wall with the same force, but only the one with the thin point moves and slides into a crack in the wall that it has created. So only that pin accelerated. F = m.a, so if F and m are the same for both pins, how come a isn't?
well friend the reason is; the thin pin exerts a greater pressure, beacuse of it small base area as compared with the "thick" pin. Hence, it waz able 2 cause a wreckage through wall by ur applied force, which inturn producd d motion!
Generally, the pressure created by a certain force "F" is inversly proportional to d area in contact.
Normal force, the one that didn't move had a force on it from the wall whereas the one which did move wasn't actually pressing right up against the wall since it was sliding into a crack so the wall wasn't pushing back as much.
For a = 0, the Sigma F equal zero, because the F you gave in was equal with the normal pressure, but when a = something not zero, the surface's shape is deformed, the normal pressure is no longer as great as before, and the backforce was friction of the nail's surface and deformed table surface, no longer normal force, efen if normal force still exist, the normal force can't be as great as before because of the vector is not 100 % to the opposite way,
to explain why the table wrecked.. well.. I think it's correlated with mohr's circle of tension-compression diagram.. or maybe molecular deform modelling.. I don't know.. I'm still a newbie, sorry for the messed up language too ^^
Thanks. So I suppose the higher the pressure on an object, the lower the normal force of the object?
FAQ: Force, pressure and acceleration
What is force?
Force is defined as any influence that causes an object to undergo a change in motion or direction. It is measured in Newtons (N) and can be represented by a vector with both magnitude and direction.
What is pressure?
Pressure is the amount of force applied per unit area. It is measured in Pascals (Pa) and can be calculated by dividing the force by the area over which it is applied. The SI unit for pressure is the Newton per square meter (N/m2).
What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is measured in meters per second squared (m/s2) and can be calculated by dividing the change in velocity by the time taken for the change to occur.
How are force, pressure, and acceleration related?
Force, pressure, and acceleration are all related by Newton's Second Law of Motion, which states that the force applied to an object is equal to the mass of the object multiplied by its acceleration. This means that an increase in force will result in an increase in pressure, and a greater acceleration will require a greater force.
What are some real-life examples of force, pressure, and acceleration?
Some examples of force include pushing a car, throwing a ball, or pulling a wagon. Examples of pressure can be found in the tires of a car, the weight of a book on a table, or the force applied by a person on a scale. Acceleration can be seen in a roller coaster ride, a car speeding up or slowing down, or a ball falling towards the ground.
