Force-Pulley problem solving for accel
In summary, a 30.7-kg block is connected to a 6.3-kg block by a massless string over a frictionless and massless pulley. A force of 224.9 N is applied to the first block at an angle of 30.5 degrees, and the coefficient of kinetic friction between the first block and the surface is 0.209. The upward acceleration of the second block can be determined by solving for the tension in the string using the free-body diagram and the equations Fnetx=m*ax and Fnety=m*ay. Trigonometric functions should not be a concern in solving the equations.
bocobuff
42
A 30.7-kg block (m1) is on a horizontal surface, connected to a 6.3-kg block (m2) hanging vertically by a massless string. The pulley is massless and frictionless. A force of 224.9 N acts on m1 at an angle of 30.5degrees. The coefficient of kinetic friction (muk between m1 and the surface is 0.209. Determine the upward acceleration of m2.
Fnetx=m*ax, Fnety=m*ay, fk=muk*Fn,
I drew the free-body diagram with normal force, Fn, and gravity, m*g, and the y component of the applied Force, Fy=F*sin30.5, on the y-axis with the Fnety= Fn+Fy-m*g=0. On the x-axis I have tension from m2, T, and fk=muk*Fn, and the x component, Fx=F*cos30.5. The Fnetx=T+muk*Fn-F*cos30.5, and I don't have a numerical solution for this yet. I know from Fnety that Fn=m*g-F*sin30.5 and that I'm looking to solve for T from m2 because that will be the same T on m2 on the other side of the pulley. From there I can solve for the acceleration easily but I'm having a terrible time with eliminating variables and isolating T. Am I looking over a trig identity or a simple substitution somewhere? Any suggestions would be great, thanks.
I've haven't looked at all your working to make sure that it's correct, but I will say that you shouldn't worry about having trigonometric functions in your equations, remember that sin(30.5) and cos(30.5) are just numbers. Just solves these two equations as you would any pair of simultaneous equations.
It seems like you are on the right track with your approach. To solve for T, you can use the equation Fnetx=T+muk*Fn-F*cos30.5 and substitute in the value for Fn that you found from Fnety. This will give you an equation with only one variable, T, which you can then solve for. Another approach could be to use the equation Fnetx=m2*ax, where ax is the acceleration of m2. From this, you can solve for ax and then use the equation ax=ay to find the upward acceleration of m2. Keep in mind that in this problem, the acceleration of m2 is equal to the acceleration of m1, since they are connected by a massless string and the pulley is frictionless. I hope this helps and good luck with your problem solving!
FAQ: Force-Pulley problem solving for accel
What is the force-pulley problem and why is it important to solve?
The force-pulley problem is a physics concept that involves using pulleys and ropes to change the direction and magnitude of forces. It is important to solve because it helps us understand the principles of mechanical advantage and force distribution, which are crucial in many engineering and design applications.
What are the key steps in solving a force-pulley problem for acceleration?
The key steps in solving a force-pulley problem for acceleration are: 1) identifying the forces acting on the system, 2) drawing a free body diagram to visualize the forces, 3) applying Newton's second law of motion (F=ma) to calculate the net force, 4) using the mechanical advantage formula (MA = load/effort) to determine the acceleration, and 5) checking for any additional constraints or factors that may affect the solution.
How does the number of pulleys in a system affect the acceleration?
The number of pulleys in a system does not affect the acceleration, but it can affect the effort required to produce a certain acceleration. This is because each additional pulley adds another point of support and changes the direction of the force, resulting in a reduction of the effort needed to lift a load. The mechanical advantage increases with the number of pulleys, allowing for a greater distribution of force and making it easier to lift heavier loads.
Can a force-pulley problem be solved without knowing the mass of the object?
Yes, a force-pulley problem can be solved without knowing the mass of the object. This is because the acceleration is dependent on the net force acting on the system, not the mass. However, knowing the mass can be helpful in determining the magnitude of the forces and the mechanical advantage.
What are some real-life examples of force-pulley problems?
Some real-life examples of force-pulley problems include lifting heavy objects using cranes or pulley systems, using a bicycle chain and gears to change the direction and magnitude of force, and using a block and tackle system to hoist sails on a sailboat. Other examples include weightlifting machines, elevators, and even simple tasks like opening a door using a doorknob and lever system.
