Force Vectors and Circular Motion
In summary, at the top of a ferris wheel, there is no acceleration in the Y direction. However, this does not mean that there are no forces acting on the object. The normal force and gravity are still present, and they are in opposite directions. The solution to this problem involves finding the net force, which is equal to mv^2/r, and setting it equal to the sum of the forces in the Y direction. This leads to the equation Fn = mg - mv^2/r. The centripetal force is not an additional force, but rather the net force acting on the object. It is important to note that the centripetal force is not a separate force, but rather a combination of real forces that are acting
Ronnin
168
This is a case where I know the results but am fighting the math. At the top of a ferris wheel your acceleration in Y is 0. Ol' Newton says all all forces then must cancel, got that. I know my weight at this point will feel less at this point. Here is where I am troubled, vector for gravity points down so does the vector for the circle's accleration but my Normal points up and must have the same magnitude as Fg and Fc. The answer given subtracts Fc from Fg to get Fn (which feels right, but contradicts my vectors). Any conceptual help is appreciated.
Your statement in bold is false. You need to rethink everything that follows it.
I realized that after I posted. I was confusing acceleration with velocity. I still have 2 force vectors working in the downward direction. I've seen the solution but they figure Fn=mv^2/r + mg, but they use a negative for the angular acceleration but a possitive for gravity. That just doesn't make since if they both point toward the center of the wheel.
The centripetal force is not an additional force in the problem. It is the name we give to the combination of forces that are causing the circular motion. The only forces acting on you are gravity and the normal force, and these are in opposite directions. You know that gravity is stronger, because the acceleration is down toward the center of the circle. If you take down as positive (the direction of the centripital force) you have
Ftotal = mg - Fn = mv^2/r , where everything represented as a letter is positive
An alternative way of looking at the problem is to treat mv^2/r as a centrifugal force (I don't recommend it) If you do this the direction of mv^2/r is upward, as is the normal force, and gravity is downward. In this case, the net force has to be zero, so you have
mg = Fn + mv^2/r
Either way you do it, you get the same result
Fn = mg - mv^2/r
You were right to question what you wrote earlier as the given answer. Writing the mv^2/r with the + and treating the term as a negative is confusing. There is no natural way to introduce a negative into this quantity.
The centrafugal way is exactly what "feels" natural in this problem but I know it's a psudo force. I still don't understand why we can ignore the centripetal acceleration because if that is so then my future trajectory would become parabolic and no longer circular. This is why I have problems because I can't "trust" any of my intuitive instincts for fear of these caviats.
Both weight and centripetal acceleration point downward and are negative.
First identify the forces:
(1) Normal force, which points upward: Fn
(2) Weight, which points downard: -mg
Now add them up:
Total force= Fn -mg
The acceleration is centripetal and points down, so: a = -v^2/r
Now apply Newton's 2nd law (total force = ma):
Fn -mg = -mv^2/r
Thus: Fn = mg -mv^2/r
Now add them up:
Total force= Fn -mg
Fn -mg = -mv^2/r
But why is the centripetal acceleration not accounted for in the total force? It is acting on the mass in the downward direction just as gravity is, right?
No. The centripetal force is not an additional force. It is the name we give to the net force acting on an object in circular motion with constant speed. That net force comes from the real forces acting on an object, such as gravity, friction, normal force. When you write the net force in terms of the contributing forces, you know that its magnitude must be mv^2/r
Edit: I added the "with constant speed". An object in circular motion could be accelerating tangentailly as well, but that is not part of this problem. The net force acting on such an object would have both a centrifugal force component and a tangential force component.
Just to add to OlderDan's explanation: "Centripetal" just means "towards the center"--it specifies a direction, not a new kind of force. You need real forces (like the seat pushing up and gravity pulling down) to provide the net force acting towards the center.
Thank you guys so much. That was exactly the point I needed clarification on.
OOPs That should have said
The net force acting on such an object would have both a centripetal force component and a tangential force component.
FAQ: Force Vectors and Circular Motion
What is a force vector?
A force vector is a mathematical representation of a force that includes both its magnitude and direction. It is typically represented by an arrow pointing in the direction of the force, with the length of the arrow proportional to the magnitude of the force.
How do force vectors affect circular motion?
Force vectors play a crucial role in circular motion by providing the necessary centripetal force to keep an object moving in a circular path. Without this force, the object would move in a straight line tangent to the circle.
What is centripetal force?
Centripetal force is the force that pulls an object towards the center of a circular path. It is always directed towards the center and is necessary to maintain circular motion.
How do you calculate the net force on an object in circular motion?
The net force on an object in circular motion can be calculated by adding up all the force vectors acting on the object and taking into account their magnitudes and directions. The net force must be equal to the centripetal force to maintain circular motion.
What are some examples of circular motion in everyday life?
Some examples of circular motion in everyday life include a car turning a corner, a spinning top, a Ferris wheel, and a satellite orbiting around the Earth. These objects experience centripetal force to maintain their circular paths.
