Forced SHM with damping problem
In summary, the conversation discusses a mass attached to a spring under the influence of gravity and a viscous damping force. A periodic force is applied and the equation of motion for the mass is given. The origin of the terms in the equation is explained and solutions for different cases are found. The sum of the solutions is shown to be a solution and relations between constants are derived. A final expression is given, but it is shown to be incorrect.
asaspades
A mass, [itex]m[/itex], attached to a spring hangs vertically downwards under gravity. It is subject to a viscous damping force proportional to its velocity. The spring constant is [itex]k > 0[/itex].
A periodic force is applied to the spring and the equation of motion for the mass is
[tex]\ddot x+ \frac{b}{m}\dot x+\omega_0^2x=fe^{i\omega t}[/tex] with [itex]b>0[/itex], [itex]m[/itex] where [itex]f = |f|e^{i\phi_f}[/itex] with [itex]|f|[/itex] and f real constants. The applied force per unit mass should be taken to be the real part of the term on the right hand side.
(i) Explain the origin of the terms in the equation of motion of the mass.
(ii) For the case f = 0, assume a solution of the form [tex]x(t)=Ce^{i\alpha t} \text{ with } C=|C|e^{i\phi_C}[/tex] where [itex]|C|[/itex] and [itex]\phi_C[/itex] are real constants. Find the real and imaginary parts of [itex]\alpha[/itex] for the case [itex]b/2m<\omega_0[/itex].
(iii) Now consider the case with [itex]f \neq 0[/itex]. Assume a solution of the form [tex]x(t) = Ae^{i\omega t} [/tex] and find an expression for the complex constant [itex]A = |A|e^{i\phi_A}[/itex] .
(iv) Show that the sum of the solutions from parts (ii) and (iii) above is also a solution to the equation of motion. The initial conditions are [itex]x(0) = 0[/itex] and [itex]\dot x(0) = 0[/itex]. Use these to find two relations between the constants [itex]|C|, C, |A|[/itex] and [itex]A[/itex]. Hence show that [tex]\tan{\phi_c} = \frac{\omega}{\omega '} \tan{\phi_A} - \frac{b}{2m\omega '},[/tex] where [itex]\omega '[/itex] is the real part of [itex]\alpha[/itex] from part (ii).
Part (i) easy
Part (ii) get [itex]\alpha = \frac{ib}{2m}\pm \sqrt{\omega_0^2 - \frac{b^2}{4m^2}}[/itex]
Part (iii) get [tex]A=\frac{f}{[(\omega_0^2 - \omega^2)^2 + b^2/m^2]^{1/2}}\left(\frac{\omega_0^2 - \omega^2}{[(\omega_0^2 - \omega^2)^2 + b^2/m^2]^{1/2}} - i\frac{b\omega/m}{[(\omega_0^2 - \omega^2)^2 + b^2/m^2]^{1/2}}\right)[/tex] giving [itex]\tan\phi_A = \frac{-b\omega/m}{\omega_0^2 - \omega^2}[/itex]
Part (iv) Obviously a combination of the two is a solution. Using the given initial conditions [itex]x(0) = A+C = 0 \Rightarrow A=-C[/itex] and [itex]\dot x(0) = i\alpha Ce^{i\alpha t} + i\omega Ae^{i\omega t} \Rightarrow \alpha e^{i\alpha t} - \omega e^{i\omega t} = 0[/itex] (not going anywhere with this part)
Since [itex] A = -C[/itex] i.e. [itex]|A|e^{i\phi_A} = -|C|e^{i\phi_C}[/itex] we also have [itex] |A||e^{i\phi_A}| = |C||e^{i\phi_C}| \Rightarrow |A|=|C| [/itex] and [itex]\phi_A = \phi_C + \pi[/itex].
Taking [itex]\tan[/itex] of both sides, [itex]\tan\phi_A = \tan\phi_B[/itex] which is wrong...
This is from a past exam paper, only 1 person was able to do it in the exam. Anyone have a flash of brilliance?
Anyone?
FAQ: Forced SHM with damping problem
What is Forced SHM with damping problem?
Forced SHM with damping is a type of oscillatory motion where a system experiences a restoring force and a damping force due to an external force. This can occur in systems such as a mass-spring system or a pendulum.
What factors affect the amplitude of forced SHM with damping?
The amplitude of forced SHM with damping is affected by the frequency and amplitude of the external force, as well as the damping coefficient of the system. A higher frequency and amplitude of the external force will result in a larger amplitude of vibration, while a higher damping coefficient will result in a smaller amplitude.
How is the motion of a damped forced SHM system described mathematically?
The motion of a damped forced SHM system can be described by the equation:
x(t) = Ae^(-bt)cos(ωt+φ)
where x(t) is the displacement of the system at time t, A is the amplitude, b is the damping coefficient, ω is the natural frequency of the system, and φ is the phase angle.
What is the resonance frequency of a forced SHM system?
The resonance frequency of a forced SHM system is the frequency at which the amplitude of vibration is maximized. It can be calculated using the equation:
ω = √(ω0^2 - (b/2m)^2)
where ω0 is the natural frequency of the undamped system, b is the damping coefficient, and m is the mass of the system.
How do you solve a forced SHM with damping problem?
To solve a forced SHM with damping problem, you will need to use the equation of motion (x(t) = Ae^(-bt)cos(ωt+φ)) and apply boundary conditions to solve for the unknown parameters. You may also need to use trigonometric identities and algebraic manipulation to simplify the equation and solve for the desired variables.
