Friction On 2 Blocks + Angled Pull
In summary: B. This law states that the net force on an object is the product of its mass and its acceleration. In this situation, you are trying to find the force required to make block B accelerate. So, you need to find both the mass of block B and the acceleration of block B. Mass = Block B weight Acceleration = Block B's acceleration in the x direction
  • #36
sandman203 said:
Ok so using the above method i get Nb = 17.481
Yes, that looks correct. You can now easily calculate the value of the friction force fB.
subbing into fxb i get ax = 2.529m/s^2 then subbing into Fxab i get 50.48N
I don't believe those values are correct. You didn't show your work so I can't see where you went wrong.
Did you try setting up Newton's 2nd law for the x-component of the forces for block B?
You have the equation [itex]\sum[/itex]Fx = fBx + NBx + Wx = mBax.
Use the free body diagram for B to get expressions for the x-components of the forces and then use the equation to solve for ax.
  • #37
Ok so Nb = 17.481
Fxb = 2*-ax = 17.481cos15 -2gsin15 + 10.4886cos15
so ax = -4.0422
Now subbing into fxab
F = 59.88N
  • #38
sandman203 said:
Ok so Nb = 17.481
We have chosen the positive direction of the x-axis to be to the left since we know that the blocks will accelerate to the left. Then ax will be a positive number. You should not put a negative sign in front of ax in the equation.
Note that NB has an x-component that is negative. Also, are you sure you used the correct trig function to get the x-component of NB? The x-component is the side opposite the 15 degree angle in the right triangle.
The weight force acts entirely along the negative y-axis. So, what is the x-component of the weight?
You have the correct expression for the x-component of the friction force.
  • #39
Ok so the x component of Wy = 0. So fxb = 2*ax = -17.481sin15 + 10.4886 cos15
so ax = 2.803m/s^2
& then F = 52.126N
  • #40
Acceleration is correct.
F is not correct. Please show your work.
  • #41
Ok so NA = 7×g - Fsin30
so FfA = 0.6 × (7×g - Fsin30)
Now Fx = m×ax = Fcos30 - FfA
From before ax = 2.803 & FfA = 0.6 × (7×g - Fsin30)
so Fx = 7×2.803 = Fcos30 - ((0.6 × 7 × g) - (0.6 × Fsin30)
Fx = 19.621 = Fcos30 - ((0.6 × 7 × g) - (0.6 × Fsin30)
Fx = 19.621 + 41.46 = Fcos30 + 0.6×Fsin30
Fx = 60.881 = F (cos30 + 0.6sin30)
Fx = F = 60.881 / (cos30 + 0.6sin30)
F = 52.21N?
So i got this second time around.. I am not sure if i subtract FfA or add it. Adding i get F = 38.053
  • #42
That all looks very good! However, did you use the correct coefficient of friction?
  • #43
hmmmm 0.6? aren't we trying to overcome the static friction? I am not sure how i'd incorporate Kinetic friction because isn't the question asking the force needed to make the block slide from rest?
  • #44
We're trying to produce enough acceleration of A so that B will slip on A. Acceleration of A implies that A is slipping on the floor. So, you need to use the coefficient of kinetic friction for the friction between the floor and A.
[I didn't see where the problem stated the system starts from rest. If so, then you should check that the force necessary to overcome the static friction between A and the floor is not greater than the force required to accelerate the system at 2.80 m/s2 once A starts sliding. But you can check that the force that is just sufficient to start A slipping is not enough force to accelerate the system at 2.80 m/s2. So, applying just enough force to start A sliding would not cause B to slip on A.]
  • #45
Ah ok, yes the question does not state that block A is at rest. I am going to go with the 0.4 co-efficient because u guys are way smarter than me. But can acceleration not imply that a body is being accelerated from rest? Anyways thanks a **** tonne for the help TSny, must of been a pain dealing with me lol.
  • #46
so FfA = 0.4 × (7×g - Fsin30)
so Fx = 7×2.803 = Fcos30 - ((0.4 × 7 × g) - (0.4 × Fsin30)
Fx = 19.621 = Fcos30 - ((0.4 × 7 × g) - (0.4 × Fsin30)
Fx = 19.621 + 27.44 = Fcos30 + 0.4×Fsin30
Fx = 47.061 = F (cos30 + 0.4sin30)
Fx = F = 47.061 / (cos30 + 0.4sin30)
F = 44.14N please tell me this is finally correct!
  • #47
That's what I got. So, I believe it's correct. Good work!
  • #48
wow ok finally haha. guess we will see when it gets marked! thanks once again for the help dude realllllllllllly appreciate it!
