Gauss Sphere Surface / U = -W / f=ma=qE
In summary, the escape speed for an electron initially at rest on the surface of a sphere with a radius of 1.0 cm and a uniformly distrubted charge of 1.6 X 10^-15 C is 1/2(mv^2).
mewon
What is the escape speed for an electron initially at rest on the surface of a sphere with a radius of 1.0 cm and a uniformly distrubted charge of 1.6 X 10^-15 C? That is, what initial speed must the electron have in order to reach an infinite distance from the sphere and have zero kinetic energy when it gets there?
E = spherical surface with q charge: 1/2Eo (q/r)
U = -W
eV = Winfinity->A
Ke = 1/2(mv^2)
f=ma=qE
Vf + Vi + Ui + Uf = 0
I've played with all these relevant equations and tried to massage the numbers, but I'm pretty off.
I know that we have equilibrium while the electron is on the charged sphere surface. We have Vi. When we reach point infinite distance from sphere we have Vf...why does it have zero kinetic energy when it gets there if Kinetic energy is different from Work? Doesn't that mean it has no mass and no velocity?
The last relevant equation gives me ideas that I should be working in two parallel equations.
Thanks in advance. It's really great to read through all the forums in here and see some of the fun challenges that lie ahead in Physics - harmonic oscillations, divergence/convergence.
potential energy
What electric potential energy does the electron have at the surface of the sphere? (How does potential energy depend on distance?)
Ui = 0 at infinity and electric potential V is also zero at infinity.
Uf/q = electric potential energy on the surface of the sphere.
Not sure what you're saying here. Initially, at the surface of the sphere, what's the potential energy of the electron? The final potential energy at infinity will be zero.
You might want to read this: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elepe.html"
Thank you for the link; that is clear and helpful (and unlike anything in my book's chapter).
I was trying to say similarly I think, applying Gauss/Coulomb ideas with:
Uf - Ui = -W
I'll try writing the math now!
Question though, why does the problem statement say that there is no "kinetic" energy when the electron reaches the infinite distance? I just saw something about this in one of the threads in here...about the electron no longer having mass at this infinite point. 0 Kinetic energy would be achieved also if there is no final velocity.
escape speed is the minimum needed to reach infinity
Because they want you to calculate the minimum speed (or kinetic energy) needed to escape and reach "infinity". That's the speed for which it just runs out of energy as it goes to infinity. You can always give the electron a greater initial speed, but then it will have more than enough energy and will never slow down to zero speed or kinetic energy.
Thank you Doc Al!
Had to take a break but I got it now ;-) It was easier than I was making it.
U = W
1/2(MV^2) = (1/4pieEo)(Qe/r)
This is a great site.
I'm paying my dues which are a great value and I'm sure I'll be here more through the next quarter Physics curriculum as well.
I am teaching post MA and have trouble getting to my Physics teacher office hours nor any school offered tutoring. It's also a way better deal and more convenient than hiring a local tutor to help on any HW problems I have questions on!
FAQ: Gauss Sphere Surface / U = -W / f=ma=qE
What is Gauss Sphere Surface?
Gauss Sphere Surface, also known as Gaussian surface, is an imaginary surface used in Gauss's law to calculate the electric field of a charge distribution. It is a closed surface that encloses a charge or a group of charges and is chosen to simplify the calculation of the electric field.
What does U = -W mean in this context?
In this context, U = -W represents the conservation of energy principle, where the change in potential energy (U) of a charged particle is equal to the negative of the work (W) done by the electric field on the particle.
How does the equation f=ma relate to Gauss Sphere Surface?
The equation f=ma, also known as Newton's second law of motion, is used to calculate the force (f) experienced by a charged particle in an electric field. The force is equal to the mass (m) of the particle multiplied by its acceleration (a), which is determined by the electric field.
What is the significance of qE in this equation?
Qe represents the electric force experienced by a charged particle in an electric field. It is calculated by multiplying the charge of the particle (q) by the strength of the electric field (E) at that point.
How is Gauss Sphere Surface/U = -W/f=ma=qE used in practical applications?
This equation is commonly used in electromagnetism to calculate and predict the behavior of charged particles in electric fields. It is also used in the design and analysis of electrical circuits and devices, such as capacitors and electric motors.
