Given a quadratic satisfy the conditions of the limit
In summary, the conversation discusses determining values for a, b, and c in the formula ax^2+bx^2 +c that satisfy certain conditions. These conditions include f(0)=0, limx->-1 F(x)=3, and limx->2 f(x)=6. The solution involves solving for c=0, b=-1, and then substituting these values to solve for a=2.
Plutonium88
174
Determine values of a, b, c in the formula ax^2+bx^2 +c that satisfy the conditions:
f(0)=0 // Limx->-1 F(x)=3 // limx->2 f(x)=6
F(0)=0 therefore x=0
so f(0)=a(0)^2+b(0)+c
so f(0)=c = 0
so c=0
2.
Lim f(x) = 3, x->-1
so f(x)=ax^2+bx+c
3 = a(-1)^2+(-b) + 0
so a= 3+b or b= a-3
3.
f(x)=6 x->2
6 = ax^2 + bx + c
6 = 4a + 2b
sub in a.
6=4(3+b) +2b
-6 = 6b
b=-1
now do the same but sub in b. to solve for a
6=4a+2b
6=4a + 2(a-3)
6=4a + 2a -6
12=6a
a=2
So therefore values are a=2, b=-1 and c=0 to satisfy those conditons.
I believe this is the correct way to go about it, but i just wanted some one to check for me if possible, and also i was curious is it because you are expressing a in terms of be and b in terms of a when taking the limit, and substituting that value into the next limit restriction 6=4a+2b that it makes it follow all of the previous conditions... (ie: c=0, b=a-3 a=3+b)
I was just curious if some one could give me some more understanding if this is correct.
Your solution is correct, but after getting b=-1, you get a=3+b=2 directly.
ehild
ehild
thank you sir.
FAQ: Given a quadratic satisfy the conditions of the limit
What is a quadratic?
A quadratic is a type of mathematical equation that contains a variable (usually denoted as x) raised to the second power, or squared. It takes the form of ax^2 + bx + c, where a, b, and c are constants.
What does it mean for a quadratic to satisfy the conditions of a limit?
When a quadratic equation satisfies the conditions of a limit, it means that as x approaches a certain value, the value of the quadratic function also approaches a certain value. In other words, the function has a well-defined value at that point.
How do I know if a quadratic satisfies the conditions of a limit?
To determine if a quadratic equation satisfies the conditions of a limit, you can use the limit definition of a derivative. If the limit of the difference quotient, or the slope of the secant line, approaches a finite value as the interval approaches 0, then the quadratic satisfies the conditions of a limit.
What happens when a quadratic does not satisfy the conditions of a limit?
If a quadratic equation does not satisfy the conditions of a limit, it means that the function has no well-defined value at that point. This could occur if the value of the function approaches infinity or does not approach a finite value as x approaches a certain value.
How can understanding the conditions of a limit for a quadratic be useful?
Understanding the conditions of a limit for a quadratic can be useful in various applications, such as optimization problems and curve sketching. It can also help in determining the behavior of a function at a certain point and finding the instantaneous rate of change of a function.
