Going backwards: finding a function from differential
In summary, the conversation discusses an expression in the form of Adx+Bdy and how to determine if it is a total differential of a function with two variables. The solution involves checking for exactness and using the Schwartz theorem. An example of a non-exact differential is also given.
Yankel
395
Hello,
I have this expression:
\[4xy^{3}\cdot dx+6x^{2}y^{2}\cdot dy\]
and I am asked to say if this expression can be a total differential of a function with two variables. If so, I need to find the function.
How can I do it ? It must involve integration somehow...
Thank you !
Yankel said:
Hello,
Thank you !
You have two differential eqution...
$\displaystyle \frac{\partial {f}}{\partial{x}} = 4\ x\ y^{3}\ (1)$
$\displaystyle \frac{\partial {f}}{\partial{y}} = 6\ x^{2}\ y^{2}\ (2)$
... and the solution both (1) an (2) is $\displaystyle f(x,y) = 2\ x^{2}\ y^{3} + c $ [c is an arbitrary constant...], that is the requested function...Kind regards$\chi$ $\sigma$
If you are given the equation:
\(\displaystyle 4xy^3\,dx+6x^2y^2\,dy=0\)
Then you may test for exactness by seeing if:
\(\displaystyle \frac{\partial}{\partial y}\left(4xy^3\right)=\frac{\partial}{\partial x}\left(6x^2y^2\right)\)
Is this condition true?
Thank you both. Can you think of an expression of the form Adx+Bdy which is not a total differential of a function, so I know how an answer of 'no' to the original question looks like ?
An expression like...
$\displaystyle \alpha(x,y)\ dx + \beta(x,y)\ d y \ (1)$
.. . is called 'exact differential' if it exists a function f(x,y) so that is...
$\displaystyle \frac{\partial {f}}{\partial{x}}= \alpha (x,y)$
... and...
$\displaystyle \frac{\partial{f}}{\partial{y}}= \beta(x,y)$
If the conditions of the Schwartz theorem are satisfied, the a sufficient condition for the existence of f(x, y) is...
$\displaystyle \frac{\partial{\alpha}}{\partial{y}} = \frac{\partial{\beta}}{\partial{x}}\ (2)$
If you don't mind me here :eek: consider $$\color{black}4xy^3 \, dx + (6x^2y^2 \color{red}+x^2 \color{black}) \, dy.$$ Then $$\frac{\partial}{\partial y} 4xy^3 = 12xy^2 \text{ and } \frac{\partial}{\partial x} 6x^2y^2 +x^2 = 12xy^2 + 2x,$$ therefore this is not an exact differential.
FAQ: Going backwards: finding a function from differential
What is the purpose of finding a function from differential?
Finding a function from differential is important in many areas of science and engineering, as it allows us to understand the relationship between two quantities and make predictions based on this relationship. It is particularly useful in fields such as physics, economics, and biology.
How do you find a function from differential?
To find a function from differential, you need to take the derivative of the function and then integrate it. This process is known as antidifferentiation or integration. It involves using mathematical techniques to reverse the process of differentiation and determine the original function.
What are some common techniques used for finding a function from differential?
There are several techniques that can be used to find a function from differential, including the method of substitution, integration by parts, and partial fractions. These methods involve manipulating the differential equation to make it easier to integrate and solve for the original function.
Are there any limitations to finding a function from differential?
Yes, there are limitations to finding a function from differential. In some cases, it may not be possible to find an exact function, and an approximate solution must be used. Additionally, some functions may have multiple solutions, making it difficult to determine the correct one.
How is finding a function from differential used in real-world applications?
Finding a function from differential is used in a wide range of real-world applications, such as predicting the motion of objects, modeling population growth, and analyzing economic trends. It is also essential in fields such as engineering, where it is used to design and optimize systems and processes.
