Graph function of f(x) with max/min. Don't know what the problem is.
In summary: HallsofIvy: I don't understand what you've done. Here's how I did it:(i) Find the values of a and b.Ans: a=4, b=-6(ii) Solve the equation f(x) = 0.Ans: x=131.8◦(iii) Sketch the graph of y = f(x).This is where I have a problem.(i) Find the values of a and b.Ans: a=4, b=-6(ii) Solve the equation f(x) = 0.Ans: x=131.8◦
SolCon
33
Hi to all. :)
So I'm having a problem with this question, but in only one part, whereas the other parts of this question were done with correct answers. The only part where I'm having a problem, concerns drawing the graph of y=f(x). Here's the question:
Q. The function f is such that f(x) = a − b cos x for 0◦ ≤ x ≤ 360◦, where a and b are positive constants. The maximum value of f(x) is 10 and the minimum value is −2.
This came in parts (i) and (ii), both of which were done:
Ans : a=4, b=-6
Ans: x=131.8◦
Here's how I tabulated the function:
http://usera.ImageCave.com/biosyn/grp%201.PNG
And here's the resulting graph:
http://usera.ImageCave.com/biosyn/grp%202.PNG
This seems to be wrong. However, I don't really know what the problem is and this is all I keep getting. :(
Hi SolCon! :smile:
Looks ok, except
what happened to 3π/2 ? :wink:
I can't see the attachments. Also,
SolCon said:
Hi to all. :)
Ans : a=4, b=-6
Why is b negative, when you stated before that a and b are positive constants?
The largest possible value for cos(x) is 1 so the smallest possible value for a- bcos(x) is a- b= -2. The smallest possible value for cos(X) is -1 so the largest possible value for a- bcos(x) is a+ b= 10.
Solve a- b= -2, a+ b= 10 for a and b.
Apologies for the late reply.
Thanks everyone for the responses. :)
tiny-tim: Yes, I forgot about that. Was going by doubling the pi value. :)
eumyang: I don't know why you can't see the images, maybe something's blocking them at your end? Also, the part where the question asks for a positive b constant and me getting a -ve one is probably the part I'm having difficulty with.
I agree with you about the fact that the greatest value of cos(x) is 1 [cos(0)]. So I did it like this:
> a-b cosx = f(x)
> a-b cos(0) = 10 [cos(0) = 10, i.e, greatest value]
> a-b(1) = 10
> a-b=10
The same with the least value of cos(x) which is -1 [cos(180)].
> a-b cos(180) = -2 [cos(180) = -2, i.e, lowest value]
> a-b(-1) = -2
> a+b = -2
This is how I got them and solved them simultaneously then. How come they not correct? :(
All I can say is that a= 4, b= -6 are the only values of a and b that will make a- bcos(x) have a maximum value of 10 and a minimum value of -2. There are not positive values that will work.
> a-b cosx = f(x)
> a-b(1) = 10
> a-b=10
> a-b(-1) = -2
> a+b = -2
You did almost what I did except: subtracting a larger number gives you a smaller number! While 1 is the largest value of cos(x), it does NOT give the largest value of a- bcos(x), it gives the smallest.
A more formal way of seeing that is: [itex]cos(x)\le 1[/itex] for all x so, multiplying both sides of that by -b, [itex]-bcos(x)\ge -b[/itex] (remember that the inequality sign switches direction when you multiply both sides by a negative number) and then, adding a to both sides, [itex]a- bcos(x)\ge a- b[/itex]. Since a- b is always less than or equal to a- bcos(x), it is the minimum value, not the maximum: a- b= -2, not 10.
Similarly, because [itex]cos(x)\ge -1[/itex], [itex]-bcos(x)\le b[/itex] and [itex]a- bcos(x)\le a+ b[/itex]. Since a- bcos(x) is always less than or equal to a+ b, a+ b is its maximum value, 10.
Now solve a- b= -2, a+ b= 10.
Once I again I thank you for the well structured explanation. It'll take me a while to completely allow the entire thing to penetrate through my skull, but I'm sure I'll get it.
Thanks for the help. :)
FAQ: Graph function of f(x) with max/min. Don't know what the problem is.
What is a graph function?
A graph function is a visual representation of a mathematical function, where the input values are plotted on the x-axis and the corresponding output values are plotted on the y-axis.
How do I graph a function of f(x)?
To graph a function of f(x), you need to first determine the domain and range of the function. Then, plot a few points by substituting different values for x and finding the corresponding y values. Finally, connect the points with a smooth curve to get the graph of the function.
What does max/min mean in a graph function?
Max/min refers to the maximum and minimum values of the function. These are the highest and lowest points on the graph, respectively.
How do I find the max/min of a graph function?
To find the max/min of a graph function, you can look for the highest and lowest points on the graph or use calculus techniques such as finding the derivative and setting it equal to 0.
What does "Don't know what the problem is" mean in the context of a graph function?
This statement typically means that the person is unsure of what specific aspect of the graph function they are having trouble with. It could refer to difficulties in understanding the concept, finding the correct approach, or solving a specific problem related to the graph function.
