Harmonic Functions and Gauss' Theorem
In summary, we are asked to prove that if a function f is harmonic in a ball with |x|<1, meaning the Laplace of f is equal to 0, and f vanishes on the surface of the ball at |x|=1, then f must equal 0 inside the ball. We are also asked what happens if the partial derivative of df/dn is equal to 0 on the surface, and to interpret these results in the context of heat flow in the ball. From this, we can deduce that if the temperature T is constant (dT/dt = 0), then the heat flow is also constant and T is harmonic. However, it is unclear what the implications of this are for the temperature
aznduk
Let f be an element of C^2 (R^3=> R) be harmonic in the ball |x|< 1 (i.e. the laplace of f would be 0). Prove that f = 0 inside if it vanishes on the surface |x|=1. What if the dF/dn=0 (partial derivative) on the surface |x|=1 [What is div(f grad f)]?
Also think of heat flow in the ball. The temperature T= T(t,x) obeys the heat equation dT/dt = laplace of T (partial derivative of the heat equation is equal to the laplace of T). For steady temperatures dT/dt = 0, so T is harmonic. Interpret the results about t in this setting.
Very faint idea on how to start, so the following might be completely wrong.
Proving that f=0 if it vanishes on the surface of the ball at |x|=1 and if the partial derivative of df/dn = 0 on the surface.
I'm assuming that x in this problem is a vector in R^3.
From the second half, I figured that d^2T/dt^2 + d^2T/dx^2 = dT / dt.
I'm assuming that x is a vector in R^3 from the first half of the problem.
In any case, I assumed that if dT/dt = 0, no heat is coming in or out.
So, T is constant throughout the ball. I'm not sure where to go from here or if this is a correct interpretation of the problem. Any help would be appreciated.
FAQ: Harmonic Functions and Gauss' Theorem
What are harmonic functions?
Harmonic functions are functions that satisfy Laplace's equation, which is a type of partial differential equation. This equation is used to describe physical phenomena such as the flow of heat or electricity.
How are harmonic functions related to Gauss' Theorem?
Gauss' Theorem, also known as the divergence theorem, states that the flux of a vector field through a closed surface is equal to the volume integral of the divergence of that vector field over the region enclosed by the surface. Since harmonic functions satisfy Laplace's equation, they also satisfy the divergence theorem.
What is the significance of harmonic functions in mathematics?
Harmonic functions have many applications in mathematics, including in potential theory, electromagnetism, and fluid dynamics. They are also important in the study of complex analysis and harmonic analysis.
How can harmonic functions be used to model physical phenomena?
Harmonic functions can be used to model physical phenomena by representing them as solutions to Laplace's equation. For example, in electrostatics, the electric potential can be modeled using a harmonic function.
What are some examples of harmonic functions?
Some common examples of harmonic functions include the electric potential in electrostatics, the temperature distribution in heat conduction, and the fluid velocity potential in fluid dynamics. Other examples include solutions to the wave equation and the Schrödinger equation.
