Having difficulty comprehending a problem in Peskin's text
In summary, the conversation discusses the bound state of positronium described by a ket, where the RHS is a superposition of kets. The matrix $\Sigma^i$ represents the two-particle wavefunction in the momentum space representation and is used to construct the positronium bound state. It contains the momentum space wavefunction $\psi_i(p)$.
kof9595995
679
In his "an introduction to quantum field theory", problem 5.4 (c), he describes a bound state of positronium as [tex]|B(k)\rangle=\sqrt{2M}\int{\frac{d^{3}p}{(2\pi)^{3}}\psi_{i}(p)a^{\dagger}_{p+\frac{k}{2}}\Sigma^{i}b^{\dagger}_{-p+\frac{k}{2}}|0\rangle}[/tex]
where [itex]\psi_{i}(p)[/itex] are the p-orbtal wavefunctions in momentum space(i=1,2,3), [itex]a^{\dagger}[/itex]and [itex]b^{\dagger}[/itex] are electron and positron creation operator, [itex]\Sigma^{i}[/itex] is some 2 by 2 matrix. I don't understand where this [itex]\Sigma^{i}[/itex] comes from. LHS of the equation is just a ket, in this case shouldn't RHS be a superposition of kets? What should I make of [itex]\Sigma^{i}[/itex]?
The wavefunction of the positronium bound state is a two-particle wavefunction, which is a function of both electron and positron coordinates. The matrix $\Sigma^i$ is used to represent the two-particle wavefunction in the momentum space representation. It is essentially a two by two matrix whose elements contain the momentum space wavefunction $\psi_i(p)$. The matrix $\Sigma^i$ is used to construct the two-particle wavefunction in the momentum space representation of the positronium bound state.
FAQ: Having difficulty comprehending a problem in Peskin's text
Why am I having difficulty comprehending a problem in Peskin's text?
It is common to experience difficulty comprehending complex concepts in scientific texts. It could be due to a lack of background knowledge, unfamiliar terminology, or the complexity of the problem itself. It is important to break down the problem into smaller parts and seek additional resources or help from a peer or mentor.
How can I improve my understanding of Peskin's text?
Improving your understanding of Peskin's text can be achieved through active reading techniques such as taking notes, summarizing key points, and asking questions. It is also helpful to consult additional resources, such as online tutorials or lecture notes, to gain a deeper understanding of the material.
What should I do if I feel stuck on a problem in Peskin's text?
If you feel stuck on a problem in Peskin's text, take a break and come back to it with a fresh perspective. It can also be helpful to discuss the problem with a peer or seek help from a professor or teaching assistant. Sometimes, talking through the problem with someone else can help clarify your understanding.
How can I approach a problem in Peskin's text more effectively?
To approach a problem in Peskin's text more effectively, it is important to read the problem carefully and identify the key concepts and equations involved. You can also try working backwards from the solution, breaking the problem into smaller parts, and utilizing any provided examples or practice problems.
Is it normal to struggle with comprehending a problem in Peskin's text?
Yes, it is completely normal to struggle with comprehending a problem in Peskin's text. Science can be complex and challenging, and it is natural to encounter difficulties along the way. The key is to persist, seek help when needed, and continue to practice and build your understanding. With time and effort, you can overcome any challenges and master the material.
