Heats generated during atmospheric entry
  • Thread starter Loren Booda
  • Tags
    Atmospheric
In summary, the conversation discusses the impact of atmospheric density on the frictional heating experienced by a standard sphere falling from infinity to the surface of a hypothetical planet. The participants consider the role of different factors such as neutronium, gaseous atmosphere, and entry speed in determining the amount of heat generated. Ultimately, they conclude that a higher atmospheric density leads to more friction and thus more heat. Factors such as buoyancy, conduction, and convection are not relevant in this scenario.
Loren Booda
3,125
Consider a hypothetical planet of given radius and mass. What atmospheric density would generate the most frictional heating on a standard sphere falling from infinity to the planet surface?
Science news on Phys.org
Neutronium, although I don't think that most people would categorize it as an 'atmosphere'.
Wouldn't neutronium, not being a fluid, inhibit the sphere from falling to the planet? I was thinking more of a gaseous atmosphere, whose density at anyone altitude (for the hypothetical planet mentioned) happens to be dependent on its depth, or total mass
At high energy, everything is a fluid. The question doesn't have an answer other than higher density = more friction.
How about higher density --> 1. more buoyancy; 2. slower entry (due to friction overall); 3. greater heat conduction
If you're dropping the object from infinity, the entry speed is determined by gravity. A thicker atmosphere doesn't change that, it just slows the object down faster once it gets there (generating more heat).
Buoyancy is not ever a factor.
Conduction and convection are not factors.
FAQ: Heats generated during atmospheric entry
What causes heat to be generated during atmospheric entry?
When an object enters the Earth's atmosphere, it encounters air molecules that are moving at high speeds. These molecules collide with the object, transferring kinetic energy and increasing its speed. This results in a tremendous amount of friction, which generates heat.
How hot can an object get during atmospheric entry?
The temperature an object can reach during atmospheric entry depends on several factors, such as its mass, speed, and shape. However, temperatures can reach up to 4,000 degrees Fahrenheit for small objects and up to 7,000 degrees Fahrenheit for larger objects.
Can an object burn up completely during atmospheric entry?
Yes, an object can completely burn up during atmospheric entry if it is small enough and has a high enough entry speed. This is known as ablation, where the intense heat causes the object to vaporize and disintegrate.
How does the angle of entry affect the amount of heat generated?
The angle of entry can significantly affect the amount of heat generated during atmospheric entry. A shallow entry angle will result in a longer, more gradual descent, allowing for more heat to dissipate. On the other hand, a steeper angle will result in a shorter and more intense entry, generating more heat.
What are some ways to protect a spacecraft from the heat of atmospheric entry?
One way to protect a spacecraft is by using heat-resistant materials, such as ceramics or special types of carbon. Another method is to use heat shields, which are designed to absorb and dissipate heat, protecting the spacecraft's interior. Some spacecraft also have ablative coatings, which vaporize and carry away heat to protect the spacecraft's surface.
