Help with Half-Life and a First-Order Process
In summary, the radioactive radon-222 gas in a basement with 4.0 x 10^13 atoms per liter of air will have a final concentration of 1.7 x 10^11 atoms per liter after one month, with a rate constant of 0.18 d^-1 and a half-life of 3.8 days. The book's answer of 5.5 is incorrect.
rneely01
½ Life and a First-Order Process
ln [R]t = -(0.18 d-1 ) (30.d)= -5.5
4.0 x 10 13atom/L
[R]t
4.0 x 10 13atom/L = e -5.5 = 0.0042
[R]t = 1.7 x 10 11 atom/L
Arrhenhius Equation
k = Ae –Ea
RT
=> -(0.18 d-1 ) (30.d)= -5.5 (should really be 5.4 not book answer of 5.5)
=> ln of 5.5 is 1.70 not .0042
=> no idea how book came up with 1.7 x 10 11 atom/L, since .0042/4.0 x 10 13atom/L is 1.05 x 10 -16 atom/L
What is the original problem?
Problem: Radioactive radon-222 gas ( 222 Rn) from natural sources can seep into the basement of a home. The half-life of 222 Rn is 3.8 days. If a basement has 4.0 x 10 13
atoms of 222 Rn per liter of air, and the radon gas is trapped in the basement, how many atoms of 222 Rn will remain after one month (30 days)?
Solution: Rate constant (k) is
K = 0.693 = 0.693 = 0.18 d-1
t ½ 3.8 d
This equation is relevant: ln [R]t = -kT
[R] 0
Equations:
[tex]\ln{\frac{A_0}{A_t}=kt[/tex]
[tex]t_{\frac{1}{2}}=\frac{\ln 2}{k}[/tex]
So our givens are ...
[tex]A_0=4\times10^{13}L^{-1}[/tex]
[tex]t_{\frac{1}{2}}=3.8d[/tex]
What we want is ...
[tex]A_t[/tex] when [tex]t=30d[/tex]
From our half-life equation, we can figure out what our constant k is. From our first-order equation, solve for our final concentration and plug in the value k that is found.
FAQ: Help with Half-Life and a First-Order Process
What is Half-Life?
Half-life is a term used in science to describe the amount of time it takes for half of a substance to decay or undergo a chemical reaction. In the context of a first-order process, it refers to the time it takes for half of the reactant to be converted into the product.
What is a First-Order Process?
A first-order process is a chemical reaction or decay in which the rate of change is directly proportional to the concentration of the reactant. This means that the reaction follows a first-order kinetic rate law, where the rate is equal to the rate constant multiplied by the reactant concentration.
How do I calculate the Half-Life of a First-Order Process?
The half-life of a first-order process can be calculated using the following formula: t1/2 = ln 2 / k, where t1/2 is the half-life, ln is the natural logarithm, and k is the rate constant. Alternatively, the half-life can be determined experimentally by measuring the time it takes for the reactant concentration to decrease by half.
Why is Half-Life important in Chemistry and Physics?
Half-life is an important concept in chemistry and physics as it allows us to predict the rate of decay or reaction of a substance. It is also used to determine the stability of isotopes and the effectiveness of radioactive materials in various applications.
How does Half-Life relate to Radioactive Decay?
Radioactive decay is a first-order process in which the nuclei of unstable atoms emit radiation to become more stable. The half-life of a radioactive material is the time it takes for half of the atoms to undergo this decay. Scientists use half-life to measure and control the amount of radiation emitted by radioactive materials.
