Helpp with thermodynamics and specific heat question
In summary: OUNT OF GAS = 43.58kJ/K / (3/2R) = 3.5kg-molesIn summary, for an ideal monatomic gas, the molar specific heat at constant volume is 3/2R, where R is the gas constant. The heat capacity at constant volume is measured to be 43.58kJ/K. Using this information, we can determine that there are 3.5kg-moles of gas present.
TheTourist
25
For an ideal monatomic gas, the molar specific heat at constant volume,
Cv=3/2R, where R is the gas constant. The heat capacity at constant volume of a gas is measured to be 43.58kJK-1. How many kg-moles of the gas are present?
Iv tried looking in the lecture notes and in the textbook, but can't find anything of use.
Iv made an attempt and got 3.5kg-moles. Not sure that its right though. I used R=kNA, where k is Boltzmann constant and NA is Avogadros number.
The heat capacity of n moles is n times the molar heat capacity.
The heat capacity of one mole of gas at constant volume is that amount heat flow required to raise the temperature one degree:
[tex]C_v = Q/\Delta T[/tex]
If there are n moles, multiply both sides by n to determine the amount of heat flow per degree of temperature change.
AM
Hello,
Thank you for reaching out for help with your thermodynamics and specific heat question. The molar specific heat at constant volume, Cv, for an ideal monatomic gas is indeed 3/2R, where R is the gas constant. However, the heat capacity at constant volume, Cv, is measured in units of energy per temperature, not energy per temperature per mole. Therefore, to solve for the number of kg-moles of gas present, we need to use the following equation:
Cv = (3/2)R * n
Where n is the number of moles of gas present. To solve for n, we can rearrange the equation as follows:
n = (Cv * 2)/(3R)
Plugging in the given value for Cv (43.58 kJ/K) and the value for R (8.314 J/molK), we get:
n = (43.58 kJ/K * 2)/(3 * 8.314 J/molK) = 3.3 kg-moles
Therefore, there are approximately 3.3 kg-moles of gas present in this system. Your attempt of 3.5 kg-moles is quite close, but it is important to remember to use consistent units in your calculations. I hope this helps clarify the solution for you. Keep up the good work in your studies!
FAQ: Helpp with thermodynamics and specific heat question
What is thermodynamics?
Thermodynamics is the branch of physics that deals with the study of heat and its relationship to other forms of energy, such as work. It also includes the study of how energy is transferred and transformed from one form to another.
What is specific heat?
Specific heat is a measure of the amount of heat required to raise the temperature of a substance by a certain amount. It is a characteristic property of a substance and is often used to identify and differentiate between different materials.
How is specific heat measured?
Specific heat is typically measured by conducting a controlled experiment in which the substance is heated by a known amount of energy and the resulting change in temperature is recorded. The specific heat is then calculated using the equation Q = mCΔT, where Q is the amount of heat energy transferred, m is the mass of the substance, C is the specific heat, and ΔT is the change in temperature.
What is the difference between specific heat and heat capacity?
Specific heat and heat capacity are often used interchangeably, but they are actually slightly different. While specific heat is a measure of the amount of heat required to raise the temperature of a unit mass of a substance by a certain amount, heat capacity is a measure of the amount of heat required to raise the temperature of an entire object by a certain amount.
How is thermodynamics used in real life?
Thermodynamics has countless applications in our daily lives. It is used in the design and operation of engines, refrigerators, air conditioners, and other heat transfer devices. It is also used in the study of weather patterns, chemical reactions, and even the human body's metabolism. Understanding thermodynamics is essential for many fields, including engineering, chemistry, and medicine.
