Hemodynamics Homework Help, Works shown
In summary: I don't know how to prove part b.)In summary, the model of the arterial tree is based on a simple branching network, with each junction having a parent vessel and daughter vessels whose diameters are related by the cube law. Part a) shows that the ratio of vessel diameters decreases with increasing generations, with a formula of D_n/D_0= 2^(-n/3). Part b) uses this formula to show that 35 generations are required to model the arterial tree from the aorta to the capillaries. Part c) asks us to derive a formula for the mean transit time, but more information is needed to solve this part.
johnq2k7
64
Model the arterial tree as a simple branching network in which each junction is composed of a parent vessel and daughter vessels, each having a diameter related to the parent's via the cube law (D_n-1)^3= (D_n*a)^3 + (D_n*b)^3 which is approx. equal to 2*(D_n)^3
a.) Show that D_n/D_0= 2^(-n/3)
b.) Show that 35 generations are required to model the arterial tree from aorta (D_0=2.6 cm) to the capillaries (D_34=10 um)
c.) Derive a formula for the mean transit time (ie vessel length divded by mean velociity) for an individual vessel. Based on this formula, how long does the model suggest it would take for blood to go from the aorta to the capillaries?
My work:
a.) since
(D_n-1)^3 is approximately equal to 2*(D_n)^3
therefore,
(D_n-1/D_n)^3= 2
therefore i Dn/Do= 2^(-n/3)
I'm not sure
i need help with the other questions, I'm confused how use this equation to solve the problem?
My work:
a.) since
therefore,
(D_n-1/D_n)^3= 2
I'm not sure
I'd guess that you just plug in n=34, n=35, n=36 into the equation, and show that you need at least n=35 in order to get the large ratio in vessel sizes that they give in the question.
How do you prove part a.) properly though, and for part c.) how do u derive the mean transit time equation from the information?
please help
please help
What are a and b in the original equation? Are they somehow constrained to be close to 1 each, and that's why the simplified approximation works?
For the proof, I'd try doing something like this...
[tex]{D_{n-1}}^3 = 2 {D_n}^3[/tex]
So
[tex]{D_0}^3 = 2 {D_1}^3[/tex]
[tex]{D_1}^3 = 2 {D_2}^3[/tex]
[tex]{D_2}^3 = 2 {D_3}^3[/tex]
etc., So
[tex]{D_0}^3 = 2 {D_1}^3 = 2^2 {D_2}^3 = 2^3 {D_3}^3 = ... = 2^n {D_n}^3[/tex]
The rest of the proof should follow. Is that what you mean?
And what does your text say about flow rate equations. There must be more information that you use to solve that part?
How about part b.)
Do you simply
use, D_0= 2.6 cm
D(34)= 10 um
and substitute
(D_0)^3 / (2^34)= 10 um
How do you prove it?
I'm sort of confused?
johnq2k7 said:
How about part b.)
Do you simply
use, D_0= 2.6 cm
D(34)= 10 um
and substitute
So what is the ratio of the 2.6cm and 10um? What is the ratio of the following?
[tex]\frac{{D_0}^3}{{D_{33}}^3}[/tex]
[tex]\frac{{D_0}^3}{{D_{34}}^3}[/tex]
[tex]\frac{{D_0}^3}{{D_{35}}^3}[/tex]
FAQ: Hemodynamics Homework Help, Works shown
What is hemodynamics?
Hemodynamics is the study of the movement and flow of blood within the body. It involves understanding the physical and mechanical factors that influence blood flow, such as pressure, volume, and resistance.
How can hemodynamics be applied in medicine?
Hemodynamics is an important tool in diagnosing and treating various medical conditions, particularly those related to the heart and blood vessels. By measuring and analyzing hemodynamic parameters, doctors can assess the health of a patient's cardiovascular system and make informed decisions about treatment options.
What is the relationship between hemodynamics and blood pressure?
Blood pressure is a key component of hemodynamics, as it is the force that drives blood flow through the body. Hemodynamics takes into account factors such as cardiac output and peripheral resistance to determine a person's blood pressure. Abnormalities in hemodynamics can lead to high or low blood pressure, which can have serious health consequences if left untreated.
What techniques are used to measure hemodynamic parameters?
There are several techniques used to measure hemodynamic parameters, including echocardiography, cardiac catheterization, and non-invasive blood pressure monitoring. These techniques allow for the measurement of parameters such as blood flow, pressure, and volume within the cardiovascular system.
What are some common hemodynamic disorders?
Some common hemodynamic disorders include hypertension (high blood pressure), hypotension (low blood pressure), and heart failure. Other conditions that can affect hemodynamics include atherosclerosis, anemia, and blood clots.
