Homogeneous equation; Initial Value
In summary, Dick is struggling with homogeneous equations and has been using separable equations. He is trying to integrate u-2ln(|u|), but gets lost. After some confusion, he realizes that he should integrate separately the du/u terms. He gets x+4=(y+2)^2+C, and C=0.
Exocer
Given,
(y+2)dx + y(x+4)dy = 0, y(-3) = -1
v=y/x
I've been REALLY struggling with homogeneous equations for some reason...I just don't understand them all.
so far I've tried two things.
(1)dx -(y)dy
(x+4) = (y+2)
Not even sure what else to do from here. I tried getting dy/dx and got
y+2 dy
y(x+4) dx
Thanks in advanced for any assistance... I've been looking at this problem for hours and have other homework to get to.
I think the idea here is to use separable equations. There should be a section in your math book on this concept.
Take your first form and integrate both sides. You've 'separated' the variables.
thanks guys.
Dick,
Glad to know i was on the right track. Just realized it isn't homogeneous.
As far as integrating:
dx/(x+4), I get lx|x+4|
how do i go about integrating
y
----- dy ?
y+2
Probably a dumb question, but I took a semester break between this and calc II, so lots of areas are rusty :(
Simply couldn't get it into du/u form..
It is dumb. :) Sorry, you are just out of practice. Try substituting u=y+2.
lol. I appreciate the honesty :smile:
u = y + 2
gives me
(U-2)
-------du
U
Which i guess can be broken up into
U
---- = 1
U
and -2/U
now all i have to integrate is
du
U
bringing the -2 outside of the integral, correct?
Sure. You might just write that as ((u-2)/u)*du=(1-2/u)*du=1*du-2*(1/u)*du. It's a little easier that trying to place the '-----' correctly. Just use parentheses. Or preferably tex if you dare.
i really appreciate the help.
so this is where I'm at.
ln |x+4| = 2*ln |Y+2| + ln C
which, IIRC gives
X+4 = (Y+2)^2 + C ?
and since you are given a certain x y value from the question, you can sub those into solve for the constant c
which, IIRC gives
X+4 = (Y+2)^2 + C ?
You missed a part. The integral of 1-2/u is u-2ln(|u|). What happened to the u?
Ok great! Thanks again guys for the help.
I'll do that and double check my answer with the one in the book.
plugging in the x and y values. C = 0
Strangely enough, the answer in the book reads:
x + 4 = (y + 2)^2*e^(-y+1)
I understand how they got everything up until the e with exponent.
hmmm I am taking a minute to look at it now. not sure where i messed up.
ah i think i see it.as you stated above, (1/u)*du is separate from (-2/u)*du correct? So i should integrate those seperately?
Edit: I see where i forgot u now.
Dick, p00nst3r, thanks for not doing the problem for me, and helping me think things through. I hate it when people do all the work for me lol.
I'll be checking back before I go to bed.
No problem. Glad to have helped!
I was actually considering doing the question for you and then I realized that I should guide you to the answer instead.
Good thing I didn't do it for you!
FAQ: Homogeneous equation; Initial Value
What is a homogeneous equation?
A homogeneous equation is a type of mathematical equation where all the terms have the same degree. This means that each term has the same number of variables and exponents.
How is a homogeneous equation different from a non-homogeneous equation?
A non-homogeneous equation has terms with different degrees, while a homogeneous equation has terms with the same degree. This difference affects the solutions of the equations and the methods used to solve them.
What is an initial value in relation to a homogeneous equation?
An initial value is a specific point on the graph of a solution to a homogeneous equation. It is used to determine the unique solution to the equation.
What is the importance of initial values in solving homogeneous equations?
Initial values are crucial in solving homogeneous equations because they help determine the specific solution to the equation. Without initial values, there can be multiple solutions or no solution at all.
What are some applications of homogeneous equations with initial values in real life?
Homogeneous equations with initial values are commonly used in physics, engineering, and economics to model and solve various systems. They can be used to predict the behavior of systems such as population growth, chemical reactions, and electrical circuits.
