Homomorphisms of Polynomials Over Integral Domains
In summary: Therefore, h is an automorphism iff c is invertible. In summary, h is an automorphism of A[x] if and only if c is invertible in A. This can be proven by showing that h is injective and surjective, using the fact that h(a(x))=a(xc) and c is invertible.
jmjlt88
96
Let A be an integral domain.
If c ε A, let h: A[x] → A[x] be defined by h(a(x))=a(cx).
Prove that h is an automorphism iff c is invertible.
This one really had me stumped. I have a general idea of what the function is doing. Now, assuming that h is an automorphism, we want to show that there is some element u such that cu=uc=1. My idea was to use the fact that h is injective. That is, if a(cx)=b(cx), then a(x)=b(x). I believe that I can get this fact to imply that c is invertible. Right approach?
Any help would be great! Thanks! :)
Yes, your approach is correct. Now, for the converse, assume c is invertible and let u be its inverse. Let a(x), b(x) ∈ A[x]. Then we have h(a(x))=a(cx) and h(b(x))=b(cx). If h(a(x))=h(b(x)), then a(cx)=b(cx). Applying u to both sides, we get a(x)=b(x). Thus, h is injective. To show that h is surjective, let y(x) ∈ A[x]. Then y(x) = y(u·cx). Let a(x) = u·y(x). Then h(a(x)) = a(cx) = u·y(cx) = y(x). Thus, h is surjective. Since h is both injective and surjective, it is an automorphism.
Related to Homomorphisms of Polynomials Over Integral Domains
1. What is a homomorphism of polynomials over integral domains?
A homomorphism of polynomials over integral domains is a function that preserves the algebraic structure of polynomials. It maps one polynomial to another, while preserving addition, multiplication, and scalar multiplication operations. In other words, the result of applying the homomorphism to the sum, product, or scalar multiple of two polynomials is the same as applying the homomorphism to each polynomial separately and then performing the operation.
2. How can homomorphisms of polynomials over integral domains be represented?
Homomorphisms of polynomials over integral domains can be represented as a set of coefficients, with the degree of each coefficient corresponding to the degree of the polynomial it is mapped to. For example, a homomorphism that maps a polynomial of degree 3 to a polynomial of degree 2 can be represented as a set of 3 coefficients.
3. What is the kernel of a homomorphism of polynomials over integral domains?
The kernel of a homomorphism of polynomials over integral domains is the set of all polynomials that are mapped to zero. In other words, it is the set of all polynomials that the homomorphism sends to the additive identity element of the target polynomial ring.
4. Why are homomorphisms of polynomials over integral domains important?
Homomorphisms of polynomials over integral domains are important because they provide a way to analyze and compare different polynomial rings. They also play a crucial role in understanding the structure and properties of integral domains, as well as in solving polynomial equations.
5. How are homomorphisms of polynomials over integral domains related to other mathematical concepts?
Homomorphisms of polynomials over integral domains are closely related to other mathematical concepts such as ring homomorphisms and field extensions. They are also used in various areas of mathematics, including algebraic geometry, number theory, and abstract algebra.
