How Are Theta_1 and Theta_2 Related in Suspended Charged Spheres?
In summary, the problem involves two small spheres of charge "q" suspended from strings of length "l" and connected at a common point. One sphere has mass m and the other has mass 2m. The angles theta_1 and theta_2 that the strings make with the vertical are small. In part (a), the relationship between theta_1 and theta_2 is found by considering the forces acting on the spheres. In part (b), the distance r between the spheres is shown to be equal to (3k*q^2*l/(2mg))^(1/3) by using approximations and equations relating the angles to the distance of the spheres from the center line.
redbeard
2 small spheres of charge "q" suspended from strings of length "l" are connected at a common point. one sphere has mass m, the other 2m. Assume angles theta_1 and theta_2 that strings make with vertical are small. (a) how are theta_1 and theta_2 related? (b) show that the distance r btw spheres is (3k*q^2*l/(2mg))^(1/3)
Refer to question
My attempt involved taking the cos and sin of both angles and getting particular geometric lengths. Ultimately, from these I got the angle from the horizontal that the higher ball is at with respect to the lower ball. I won't list this here as this is largely a dead end.
It would be far too hard to separate theta 1 and theta 2 in the component eqns. The math should be far easier than this considering all the other questions were much simpler (and this is only question 3 of 7). My guess is I can use the approximation somewhere. Assuming that the 2 balls are roughly on the same horizontal plane makes for an easy solution (angle1 = 2*angle 2), but I was hesitant to employ this particular approximation.
I realize this question is more complicated, so I hope there are any takers out there.
Quite an interesting problem!
I get the answer when I assume that
means that the two strings are hanging from a common point, not that the spheres are touching.
It is one of those problems where you work with the forces on the charged spheres. The electric force pushes them apart, the gravitational forces pull them down and the tension forces in the strings pull them at an angle. You must make a force diagram for each sphere showing all those forces. Write that, in each case, the horizontal forces total zero and the vertical forces total zero (because they are not accelerating and F = ma). For each sphere, solve one formula for the tension and sub that into the other to get a formula for the electric force. The electric force on one sphere is the same as on the other, so you quickly get a relationship between the two angles to answer part (a).
(b) involves some tricky work with the same equations. It says the angles are small, so you can assume that tan θ is approximately equal to sin θ, which can be expressed as the distance of the sphere from the center line divided by the length of the string. That's how you get the L in the formulas. That 3/2 comes from adding the two distances from the center line to get r, the total distance between the spheres.
Can't give more details until I see your try!
FAQ: How Are Theta_1 and Theta_2 Related in Suspended Charged Spheres?
What is the significance of the weights and charges of the balls in this experiment?
The weights and charges of the balls play a crucial role in determining the behavior of the system. The weight of each ball affects the tension in the strings, while the charges determine the strength of the electrical force between the balls.
How does the distance between the balls affect their movement?
The distance between the balls affects the strength of the electrical force between them. As the distance decreases, the force increases, causing the balls to move closer together. On the other hand, increasing the distance decreases the force and causes the balls to move farther apart.
Can the balls have the same weight and charge and still exhibit interesting behavior?
Yes, even if the balls have the same weight and charge, they can still exhibit interesting behavior. This is because the system is affected by other factors such as the length of the strings, the angle at which the strings are attached, and external forces like air resistance.
How does changing the charge of one ball affect the behavior of the system?
Changing the charge of one ball can significantly impact the behavior of the system. If one ball has a higher charge, it will experience a stronger force and move towards the other ball. This can cause the balls to oscillate or even collide with each other.
How can this experiment be used to study the principles of electrostatics and mechanics?
This experiment can be used to study various principles of electrostatics and mechanics, such as Coulomb's Law, Newton's Laws of Motion, and the concept of equilibrium. By observing the behavior of the system and analyzing the forces acting on the balls, we can better understand these fundamental principles.
