How Do I Prove Ring Properties and Understand Their Structures?
  • Thread starter DanielThrice
  • Tags
    Ring
In summary, the conversation discusses working with elementary rings and the difficulties the speaker is having understanding them. They ask for help with proving that a given set is a subring and determining if it is commutative, has an identity, is an integral domain, a division ring, a skew field, and a field. The expert advises to do the arithmetic and apply the definitions of these mathematical structures to gain a better understanding. They also emphasize the importance of working through examples to solidify understanding.
DanielThrice
29
I'm working with elementary rings, and my professor gave me about ten of these to start but it seems like a lot of work with how he managed it. I know you guys don't answer homework so I chose so I can do the others. Any help would be greatly appreciated, the groups were easy but the rings are a little more difficult for me to grasp.
Consider the set R = {a + b (SQRT 2): a, b are in Z}
Prove that R is a subring of R.
Is R commutative?
Does R have identity?
Is R an integral domain?
Is R a division ring?
Is R a skew fi eld?
Is R a field?
Can someone explain how I go about doing these processes?
It's a really bad idea to use the same symbol, R, to mean two different things! I am going to use "R" to mean the usual real numbers and R' to mean this new set.
Is R commutative?
Is R a skew fi eld?
Is R a field?
Yes- do the arithmetic! any thing in this new set, R', is of the form [itex]a+ b\sqrt{2}[/itex] where a and b are integers. What is the sum of two such things, [itex]a+ b\sqrt{2}[/itex] and [itex]c+ d\sqrt{2}[/itex]? What is their product? Is [itex](a+ b\sqrt{2})(c+ d\sqrt{2})= (c+ d\sqrt{2})(a+ b\sqrt{2})[/itex]? If, for any a, b, it were true that [itex](a+ b\sqrt{2})(x+ y\sqrt{2})= a+ b\sqrt{2}[/itex], what would x and y have to be?
As for the others, what are the definitions of "integral domain", "division ring", "skew field", and "field"?
You just have to apply the definitions, and see if they are true or false for the mathematical object that was defined in each question.
You are right, rings, integral domains, fields, etc are rather more complicated than groups.
The point of working through ALL the different examples yourself is so you begin to see what are the differences between the various mathematical structures, so you can relate the "abstract" ideas that will come up later in the course to these "concrete" examples, and invent more examples of your own to test out conjectures, etc.
Doing this may seem tedious, but if if you don't get a solid undertanding of what rings, integral domains, etc "really are" and what are the differences between them, it is more likely you will get lost later in the course because "you can't the forest becaose of all the trees".
FAQ: How Do I Prove Ring Properties and Understand Their Structures?
What is a proving ring and why is it important to understand its properties?
A proving ring is a device used to measure force or weight. It is important to understand its properties because it is commonly used in many engineering and scientific applications to accurately measure forces and weights.
What are the main properties of a proving ring?
The main properties of a proving ring include its sensitivity, accuracy, repeatability, and range. Sensitivity refers to the smallest change in force that can be detected by the ring. Accuracy refers to how closely the ring's measurements match the true value. Repeatability refers to the consistency of measurements when the same force is applied multiple times. Range refers to the maximum and minimum forces that the ring can measure.
How do you determine the sensitivity of a proving ring?
The sensitivity of a proving ring can be determined by dividing the change in force by the corresponding change in deflection. This value is usually expressed in units of force per unit of deflection, such as N/mm or lbs/in.
Can a proving ring be calibrated?
Yes, a proving ring can be calibrated to ensure its accuracy. This is typically done by applying known weights or forces to the ring and comparing the measurements to the known values. If there are any discrepancies, adjustments can be made to correct the readings.
What are some common applications of proving rings?
Proving rings are commonly used in materials testing, load cell calibration, force measurement in industrial processes, and testing the strength of structures and materials. They are also used in laboratory experiments and research studies in various fields of science and engineering.
