How Do You Calculate ΔH and Determine Volume Changes in Thermodynamics?
In summary, the conversation discusses a homework problem where ∆U = − 225 kJ and +52 kJ of expansion work is done at constant pressure. The question is to determine ∆H and whether the volume increases or decreases. The relationship between ∆U, ∆H, and work (done on or by the system) is explained, and it is clarified that there is no double negative leading to +52 kJ. The correct equation for the problem is -225 kJ = -173 kJ - 52 kJ.
deviljay
Hi All!
I ran across a homework problem ans am confused by the question.
here it is:
For a certain process at constant pressure, ∆U = − 225 kJ and +52 kJ of expansion work is
done. What is ∆H for this process and does the volume increase or decrease?
I know that ∆U=q+w and therefore q=-277 kJ, also I know that change in enthalpy = ∆U-P∆V.
However I am all confused on the relationship between these variables.
I appreciate any feedback. Thank you for your time.
delta U = delta H - work ( done on the system or by the system )
delta U , internal energy can be gained or lost
delta H , is negative if heat is evolved and positive if heat is absorbed.
work = PdeltaV and is negative if done by the system , as in expansion
and is positive if done on the system.
So the double negative gave you the + 52 kJ
deviljay said:
Hi All!
here it is:
correction to my previous reply: there is no double negative giving a + 52 kJ
delta U = delta H - work,PV so in the above problem it should be
FAQ: How Do You Calculate ΔH and Determine Volume Changes in Thermodynamics?
What is enthalpy?
Enthalpy is a thermodynamic property that describes the total amount of heat energy in a system at a constant pressure.
Why is enthalpy important in chemistry?
Enthalpy is important in chemistry because it helps us understand the energy changes that occur during chemical reactions. It also allows us to predict the direction and extent of a reaction.
How is enthalpy related to heat?
Enthalpy is directly related to heat as it measures the amount of heat energy in a system. A change in enthalpy can indicate whether heat is being absorbed or released in a reaction.
What is the difference between enthalpy and energy?
Enthalpy and energy are closely related, but enthalpy also takes into account the pressure and volume of a system. It is a more comprehensive measure of the energy in a system than just energy alone.
How can enthalpy be calculated or measured?
Enthalpy can be calculated using the formula ΔH = Hfinal - Hinitial, where H represents enthalpy. It can also be measured using calorimetry, which involves measuring the heat released or absorbed during a reaction.
