How do you derive this x^(x/8)=4x
  • Thread starter reverend
  • Tags
    Derive
In summary, to find the derivative of x^(x/8)=4x, you can first let y=x^(x/8) and then differentiate both sides to get (1/8 + (1/8)ln x)x^(x/8)= 4. There may be confusion as to whether "=" should be a typo for "-" in the original equation, but the correct answer for either case is (1/8 + (1/8)ln x)x^(x/8)- 4. Additionally, if differentiating a function with an exponent that contains another function, both the power law and exponential law must be applied.
reverend
How do you derivate this:
x^(x/8)=4x
Can anyone help?
I don't think you can differentiate it, but I might be wrong
Functions have derivatives. Equations do not.
y = x^(x/8),
ln y = x/8 ln x
(1/y)(dy/dx) = (x/8)(1/x) + (1/8)ln x
(dy/dx) = y(1/8 + (1/8)ln x)
dy/dx = (1/8 + (1/8)ln x)x^(x/8)
Im not sure if this is allowed. Certainly the power rule isn't allowed (eg. to say d/dx x^x = x*x^(x-1)) because the power is a function of x. But I am not sure if you can differentiate implicitly like this either...
I think you misread the original post. But for the problem you gave, it looks good to me.
Theres only one variable in your equation. What do you want to differentiate and with respect to what?
A derivative is a rate of change. A relative "growth" to something. You cannot possibly differentiate this, as there is only one variable, if you wish to see it that way. You COULD differentiate it with respect to itself, but i think you will find that that will not take long. I think there is an error in the problem.
x^(x/8)=4x means as far as I can tell a y=X^(x/8)-4x so he's probably looknig for a min or a max of it? It's poorly expressed to say the least.
But there is no y variable. You could imply it to mean y=4x-x^(x/8) as well
I certainly wouln't assume that. I would assume the original post was asking how to differentiate both sides of the equation.
MichaelW24 already did the hard part: if you let y= x^(x/8) then
y'= (1/8 + (1/8)ln x)x^(x/8).
That's the left side of the equation. Differentiating both sides of the equation x^(x/8)=4x gives simply (1/8 + (1/8)ln x)x^(x/8)= 4.
IF "=" was a typo for "-" then the derivative of x^(x/8)- 4x is
By the way, if you have to differentiate
[tex]y= f(x)^{g(x)}[/tex]
There are two mistakes you might make:
1. Treat the "g(x)" as if it were a constant and use the power law
[tex]y'= (g(x))f(x)^{g(x)-1}f'(x)[/tex]
2. Treat the "f(x)" as if it were a constant and use the exponential law
[tex]y'= ln(f(x))f(x)^{g(x)}g'(x)[/tex]
Of course, the correct answer is the sum of those:
[tex]y'= (g(x))f(x)^{g(x)-1}f'(x)+ ln(f(x))f(x)^{g(x)}g'(x)[/tex]!
FAQ: How do you derive this x^(x/8)=4x
What is the purpose of deriving x^(x/8)=4x?
The purpose of deriving x^(x/8)=4x is to find the value of x that satisfies this equation. This can be useful in solving various mathematical problems or in understanding the behavior of exponential functions.
What is the process for deriving x^(x/8)=4x?
The process for deriving x^(x/8)=4x involves using logarithms to isolate the variable x. Specifically, we can take the natural log of both sides of the equation, apply the power rule of logarithms, and then solve for x.
Can this equation be solved without using logarithms?
Yes, there are alternative methods for solving this equation, such as using graphing or numerical methods. However, using logarithms is the most straightforward and commonly used approach.
What are the possible solutions to x^(x/8)=4x?
The possible solutions to x^(x/8)=4x depend on the context of the problem. In general, there can be multiple solutions or no solutions at all. In this particular equation, the most common solution is x=8, but there may be other values of x that also satisfy the equation.
How can this equation be applied in real-world situations?
This equation can be applied in many real-world situations, such as calculating compound interest, modeling population growth, or analyzing the decay of radioactive substances. It can also be used in various engineering and scientific fields to understand exponential relationships between different variables.
