How do you ground a current in a circuit?
In summary: In this case, the point with more voltage is the battery, and the point with less voltage is the ground.
Nerdydude101
54
So i am relatively new to electronics and i was wondering, on a circuit there will be grounds but its not an actual wire running into the ground, especially on small circuits in phones and stuff, so how is it grounded and what is used to ground it?
ground is the name used used when electrons return to their 'ground state' meaning they have no difference of voltage potential between their positive and negative charges. the ground in the dirt is referred to as 'earth ground' and it completes the loop in voltage differences between charges when conducting as a ground. you can think of it as the electrons going from negative to positive always looking to go too an equilibrium state. in a phone with a battery you could think of the negative terminal as being ground, the positive terminal will send electrons through the phone because opposite charges attract each other.
someone else may want to chime in with why the ground symbol is placed on the negative rail when charges go from negative to positive, I used to know the difference between conventional current flow and the other one? please enlighten me. lol
You can't actually "ground it"...in the ground.
In a residential, commercial or industrial site there are certainly grounds earthed into the earth. The power station has grounds earthed in it's transformers, so all grounds essentially return to their nearest transformer. Hence we must "earth" the grounds so they can get to the "earthed" grounds of it's near transformer supply.
Your phone or electronics are different because they don't have an AC power plant powering them...
They instead use a battery. A DC battery.
Take your car for instance. The entire chasis is grounded to the battery. If you take any 12 volt load and touch its positive terminal to the battery, you can take it's negative terminal and touch it anywhere on the frame. The load will then have current through it. To avoid any short circuits, the car uses a fuse box. If hot touches ground anywhere, this will also short the fuse.
Your phone and small electronics work the same way. The metal chassis is grounded, little fuse box in there somewhere, hot to negative or hot to ground you get 5 volts DC in many cases. It's grounded, just not into the Earth. You need to ground to your power supply inside of your hand held DC electronic device, not the Earth.
So in summary, you need to consider where your supply voltage comes from. (yes, your phone plugs into the wall, but what actually powers the phone comes from the small battery inside...not the wall socket. The wall socket does however charge the battery with transformer and full wave recitifier...or other method perhaps)
Unfortunately, no one has invented a AC battery yet. But even if they did, you will still need to ground to the inside of your electronic hand held device.
"Ground" is a sloppy term , misused almost universally.
What it usually means is "Circuit Common" or "Power Supply Return". That may or may not be connected to the earth.
If you believe Kirchoff's current law, you know that current must get back to where it started. If it leaves the positive end of a flashlight battery it must get back to the negative end of that same battery.
It is traditional to tie the negative side of a power supply or battery to a point that collects all the currents returning from various loads and call that point "Circuit Common" or "power supply return". A sloppy draftsman or engineer will call it "Ground", even though it has no connection to the earth...
Car companies still call "Chassis" "Ground" though it's insulated from ground by the tires.
Missile and aviation stuff that I've seen calls their chassis more correctly, "Vehicle Skin". Obviously an airplane in flight isn't grounded.
The British use the term "Earth" instead of "Ground" which i like.
So please form the habit early in your career of calling circuit common by that name, it'll save you confusion later on.
I use the term "Earth Ground" for a wire sunk into the earth, and i correct people (to their occasional annoyance) who speak of circuit common as "ground". I'm old enough to get away with that but you may not be so proceed judiciously.
The telephone company does tie their circuit common to earth. So does power company.
But your TV set's circuit common is very well insulated from Earth ground. Else it'd have a three prong power plug.
If you encounter an old Chrysler or Volkswagen you will find the battery's positive terminal tied to chassis instead of the negative and the car described as "Positive Ground". That's blown up a lot of aftermarket radio installations .
I know above sounds overly-fastidious but "ground" an important concept. And I'm a potentate-level nerd.
old jim
Grounding a current in a circuit refers to the process of connecting the circuit to a reference point or voltage level, usually referred to as ground. This is important as it provides a common reference point for all the components in the circuit and allows for the flow of current.
In small circuits, such as those found in phones, the ground is typically connected to the negative terminal of the battery or power supply. This creates a potential difference between the positive and negative terminals, which allows for the flow of current.
Grounding can also be achieved by connecting the circuit to a conductive material, such as a metal chassis or a copper trace on a circuit board. This provides a low-resistance path for current to flow to the ground, preventing any buildup of excess charge in the circuit.
In more complex circuits, multiple grounding points may be used to ensure a stable and reliable reference voltage throughout the circuit. It is important to carefully design and implement grounding in a circuit to avoid issues such as noise and interference.
In summary, grounding a current in a circuit is achieved by connecting the circuit to a reference point or voltage level, typically the negative terminal of the power supply, to provide a common reference for the flow of current.
Related to How do you ground a current in a circuit?
1. How do you ground a current in a circuit?
To ground a current in a circuit, a ground wire or connection must be established between the circuit and the earth. This can be done by connecting the circuit's ground terminal to a metal rod or pipe that is buried in the ground.
2. Why is it important to ground a current in a circuit?
Grounding a current in a circuit helps to prevent electrical shock and protects the circuit from damage. It also helps to stabilize the voltage in the circuit, ensuring that all components are operating at the same potential.
3. Can a circuit function without being grounded?
Yes, a circuit can still function without being grounded, but it is not recommended. Grounding is an important safety measure and also helps to maintain the stability of the circuit.
4. How do you know if a circuit is properly grounded?
To ensure that a circuit is properly grounded, a multimeter can be used to measure the voltage between the circuit's ground terminal and a known ground point. The reading should be close to zero if the circuit is properly grounded.
5. Can you ground a circuit using any type of wire?
No, it is important to use a wire specifically designed for grounding, such as a green or bare copper wire. This type of wire has a lower resistance and is better equipped to handle the high current flow during a fault.
