How do you measure voltage of cell?
In summary: If the unknown voltage was below the standard, the galvanometer would deflect downward; if the unknown voltage was above the standard, the galvanometer would deflect upward. We used the deflection as a measure of voltage. After 1960, we used a precision zener diode to balance the unknown voltage against a Josephson junction standard cell (about 1.5 volts) by "zeroing" the galvanometer. If the unknown voltage was below the standard, the galvanometer would deflect downward; if the unknown voltage was above the standard, the galvanometer would deflect upward. We used the deflection as a measure of voltage. The Weston standard cell was calibrated to have a resistance of 1.02 volts per amp. The Josephson junction standard cell was
jd12345
256
How can you measure voltage - my friend confused me.
We all know we can do it by a voltmeter but a voltmeter is a galvanometer and we need to know the resistance of the galvanometer and current passing through it to find voltage
But to find out resistance we need to know current and voltage - and for current we need voltage and resistacne
turns out that we need the other two to determine the value--- then how do we measure the emf of a cell, resistance of a wire and current?
just use a voltmeter (or a multimeter in voltmeter mode) directly on the two electrodes of your cell. This will give you open circuit voltage.
if you you have more than one resister, then you can find out how much voltage is dropped across either resistor by using a voltmeter across one the resistor in question
It's true that the voltage you measure is not the exact open-circuit voltage of the cell, but for all practical purposes, it is as close as we care. Were there a need to be painstakingly exact, then you could make use of the specification sheet that comes with every voltmeter telling you how many kΩ/V resistance it presents at the terminals for its different voltage ranges. You can then make some calculations and slightly adjust your voltage measurement. https://www.physicsforums.com/images/icons/icon6.gif
No no - this was not my question!
My question is a bit strange - perhaps hard to tell but please try to understand
So my question :-We make a voltmeter using a galvanometer and a high resistance and then to caliberate the galvanometer we need to know resistance of the galvanometer first! But then how do we find out its resistance - by doing the ohm's law experiement - by finding the ratio of V/I but for that we need to know the value of V - the thing we are trying to find!
1.Resistance can be measured by use of a bridge circuit.
2.Voltmeters can be calibrated with comparison circuits and by using a power supply of known EMF.
For details google
1."Wheatstone bridge"
2 "Potentiometer circuits"and "standard cells"
These are time consuming,but depending on the actual circuitry/equipment used used can be very accurate methods.
You calibrate a voltmeter by using a standard voltage reference, and adjusting the resistance until the meter produces the right value.
In the past standard batteries were used, and later zener diodes, but nowadays apparently a superconducting josephson junction.
http://en.wikipedia.org/wiki/Voltage_reference
before 1960, we used a precision Wheatstone bridge to balance the unknown voltage against a Weston standard (wet) cell (about 1.02 volts) by "zeroing" the galvanometer.
FAQ: How do you measure voltage of cell?
How do you measure voltage of a cell?
The voltage of a cell can be measured using a voltmeter, which is a device that measures the potential difference between two points in an electrical circuit. To measure the voltage of a cell, the positive and negative terminals of the voltmeter are connected to the corresponding terminals of the cell.
What is the unit of measurement for voltage?
The unit of measurement for voltage is volts (V). This unit is named after the Italian physicist Alessandro Volta, who invented the first electric battery.
Why is it important to measure the voltage of a cell?
Measuring the voltage of a cell is important because it allows us to determine the electrical potential difference between the positive and negative terminals of the cell. This information is essential for understanding the functioning and performance of electronic devices and circuits.
How does the voltage of a cell affect its performance?
The voltage of a cell directly affects its performance. A higher voltage means that the cell can deliver more energy, while a lower voltage means it has less energy to provide. The voltage also determines the direction of the current flow in a circuit, which is crucial for the proper functioning of electronic devices.
Can the voltage of a cell be too high or too low?
Yes, the voltage of a cell can be too high or too low. If the voltage is too high, it can damage electronic devices and may even cause a fire hazard. On the other hand, if the voltage is too low, the device may not function properly or at all. It is important to use the correct voltage for each electronic device to ensure safe and efficient operation.
