How does a photon carry force?
In summary, the conversation discusses the question of how a photon carries or transmits the force of the electromagnetic field. The participants bring up theories and concepts such as Feynman's QED, interference between cases of photon exchange, and the direction of ripples in the EM field. Ultimately, it is suggested that the force from a photon can exist in any direction, even if the EM perturbation is in a different direction.
FireBones
103
I've looked through about 40-50 of the threads dealing with photons and have not found one that describes how the photon transmits the force of the EM field.
In Feynman's QED, he talks about how a nucleus keeps an electron in orbit by exchange of photons, but I don't see how a photon can provide a push, much less a pull.
If I think of photon as a light quanta and consider light as a perturbation in the EM field, I'm stymied by the fact that the ripples in the EM field are transverse to the direction of propagation. A particle at (1,0,0) transmitting a light quanta to a particle at (0,0,0) creates an EM wave that oscillates in the y- and z-directions, so this does not seem availing to a force in the x-direction.
FireBones said:
… I'm stymied by the fact that the ripples in the EM field are transverse to the direction of propagation. A particle at (1,0,0) transmitting a light quanta to a particle at (0,0,0) creates an EM wave that oscillates in the y- and z-directions, so this does not seem availing to a force in the x-direction.
Hi FireBones! :smile:
(leaving aside the question of whether photons do transmit EM force …)
The ripples look longitudinal to me, just like the ripples when you throw a stone into water.
And the energy flow of an EM field with (transverse) electric and magnetic components E and B is in the direction of the Poynting vector, E x B.
Consider an electron some distance, much more than the size of an atom, from a proton. (Let's not worry for the moment about what happens at the atomic scale.)
The reason the electron accelerates is because of interference between the case where a photon is exchanged, and the case where it isn't.
To start, do you understand why the electron doesn't accelerate if the proton isn't there? Why it approximately obeys Newton's first law?
I'm not concerned with energy flow here. I'm interested in force.
Ripples caused by a stone thrown into water are transverse.
Jeblack, I don't really know what to make of your question... I guess I don't know why an electron wouldn't obey Newton's first law...
But I am interested in understanding how "interference between the case where a photon is exchanged and the case where it isn't" causes the acceleration.
An electron pushes on all other electrons around it.
If electron1 is pushing on electron2 and e1 accelerates in a perpendicular direction the pushing force of e1 on e2 will now have an additional component in this perpendicular direction.
This component is what we measure as the force of the electromagnetic wave on another electron. The original electric force is not commonly included in equations, though it comes up every once in awhile.
The act of applying a force in a way is like making a connection between you and the object. If you are pushing on a wall and you simultaneously start pushing up with your legs you will find that you are now pushing the wall both away from you and up. Not that it will go anywhere.
For a complete understanding see http://web.mit.edu/smcs/8.02/
The photon provides kinetic energy, the direction does not matter. The reason why is because there is no physical state that exists where the electron crashes into the nucleus. This means that if an electron is given kinetic energy it will always be beneficial to keeping the electron in orbit.
I don't see how this relates to my original question.
Yes, if one electron moves perpendicular with respect to the displacement vector between them, the new force will have a component perpendicular to the old displacement vector...but what does that have to do with anything?
My question is "how does a proton (at rest) exert force on an electron by means of a photon." How does a photon "carry force" in the x-direction if its EM perturbation is in the y/z plane?
The same way the force from an electron still maintains a force in the x-direction when the EM is in the y/z. In an EM wave there is always a force in every direction, because of the pure electric and magenetic forces.
I'm not interested in "why doesn't the electron crash into the nucleus" questions...I'm interested in how the photon allows the proton to exert force on the electron. And I fail to see how force [a vector quantity] can be articulated upon an object purely by its receipt of energy. Clearly direction does matter since force is not a scalar.
Nothing you have said has explained how a photon allows one charged particle to exert forces on another.
Doesn't, "By adding energy and possibly causing emission" answer that question? It seems fundamental to the issue of emitters and absorbers, and I'm not clear where your confusion is coming from.
How charged particles exert forces on each other I do not think we have an explanation for.
What you are asking is how does the electric force exist.
There may be a QM explanation for it, but its way beyond me if there is. From what I understand we only know the properties of the electric force.
The energetic (non virtual) photon is the one you describe and it would transmit a transvers force. These are waves.
The force you describe is longitudinal but the photons have no energy. They are virtual with infinite wavelength (or perhaps an undefined wavelength?).
A virtual photon is not a free quantum like the light emitted by an atom. It has zero energy.
Because simply adding energy does not explain the exertion of a force.
Forget the proton/electron example for now. Just consider two electrons in free space. One electron [A] at (0,0,0), the other at (1,0,0).
Now, how does a photon traveling from A to B pull B toward A? Simply saying that "B absorbs the photon, increasing its kinetic energy" doesn't give any indication of why B should be accelerated in the direction of A.
energy is a scalar, so you cannot explain a force exerted by an object as purely due to the energy... To use a rather silly personification: an electron that gains energy might know it should be speeding up, but it won't know in what direction.
Furthermore, if electron B happens to be moving with respect to electron A, this force might not be increasing its kinetic energy.
The issue here is not ionization energy and atomic physics. I was just using Feynman's book as an example of someone talking about force exchange through photons. I'm talking about the very general question of "how does a photon exert force in a direction parallel to its transmission?"
The only current answer I know of is that involving the exchange of virtual photons, which to me is the same as "We can make it work on paper, but this isn't real life." As for assigning an electron a direction... that seem to fly in the face of how an electron is defined in QM.
That helps a little...at least it basically says "Anything you know about photon as a light quanta has nothing at all to do with how photon act as force carriers."
But it also seems to me that you are saying we have no idea how or why photons exert force...but rather that they simply do.
Do these virtual photons have momentum? It seems like they must since they are essentially transferring momentum from one particle to the other. Except it would also mean that, in some cases, the photons have momenta in the direction opposite to their motion
Can anyone elaborate/confirm/correct this?
it seems pretty strange for photons to be conceived of in these two completely different ways...
I think we need a mentor or advisor on this one. Tiny Tim... Don't go tiptoeing through the tulips yet!
The way photons exert forces on charges is by modifying the phase term in thei QM wave function. The presence of an electric field will shift the position and momentum of the electrons wave packet. One might say there's no force, just a readjustment to the dynamic variables of the electron. In doing this the photon is absorbed (including it's energy). This is how it works for virtual photons too except the QM phase change is pointed longitudinally and the energy gained doesn't come from the virtual quantum but from the radiation fields of the accelerating charges.
In other words no energy is expended by pulling on something. It has to move as a result of your pulling on it.
... So this is just another aspect of Perturbation in a QFT?
Jeblack,
I found a discussion that appears to explain what is going on by passing to momentum space, and I think it is saying the same thing you are.
http://math.ucr.edu/home/baez/physics/Quantum/virtual_particles.html"
I need to reread this discussion, but it is along the lines of what I was looking for. An honest effort to explain how photons actually can transmit force.
Thanks, Antiphon...can you take a look at the link I just posted in my response to jeblack and see if it is what you are getting at? It is the sort of argument I can follow, so if that is what you are discussing, then I think I'm good here. If not, feel free to critique his version or modify it, etc.
I found that article well written in the sense that it was very much focused on answering just the question involved [and cutting through a bunch of other considerations that are important when doing calculations but not so important when trying to drill down on this one specific conceptual issue.)
OK, I think we are getting to the kernel of the problem. This has nothing to do with photons or quantum mechanics: force is the gradient of potential energy. Are you OK with this or do we have to address it?
o:) Sock it to me? o:)
Actually, I've been hiding in the tulips :redface:, because this whole discussion is getting totally weird.
i] Virtual photons don't exist (except in the maths) … they aren't real … the clue's in the name! :wink:
ii] virtual photons (in the maths) do have energy, and do have momentum, but they aren't connected to each other by the on-shell equation
For a very full discussion on virtual photons, see the thread https://www.physicsforums.com/showthread.php?t=372021" :smile:
(btw, Vanadium 50 :smile: knows a lot more about this than i do!)
My question is "how do photons carry force," so I think it pertains to both photons and [if Jeblack and a Antiphon are to be believed] quantum mechanics.
I can except how an energy field gives rise to force [because its gradient obviously is a vector], but that was not my objection. A previous post-er was saying that "force" was due to the particle receiving energy. I don't think he had a potential field in mind, as he was referring to a photon transmitting that energy.
I don't blame you at all, but to be fair I think the "non-existent" (beyond the math and diagrams) nature of virtual photons was established. Really, someday there has to be a better way of describing ths interaction without such confusing language; "virtual photons"... that is begging for misunderstandings.
As for the last, the only example I can think of would be Hawking Radiation, but then, those photons are not virtual... (head... hurts).
I don't see what is weird about it...other than that several people appeared to ignore the question I was asking...which seems like a perfectly reasonable question: If photons are the mediator of the EM force, then how do they do it?
I think the link I posted explains this in the way that Jeblack and Antiphon were hinting at.
What is "real"? Just because something is called "virtual" doesn't mean it doesn't exist. The algebraic extension of the Real numbers to make it algebraically closed is called the "imaginary" unit but imaginary numbers have real manifestations. One could make an argument that negative numbers are no more "real" than imaginary ones...they both are algebraically motivated elements that have manifestations in the real world.
But getting back to virtual photons. You say they "aren't real." If you simply mean that they cannot be detected, then the question becomes "what does it mean for something to be detected?" Quarks were originally simply seen (at least by some physicists) as mere mathematical abstractions, or "ways to make the math work out."
If we have as our model the standard model, which says that the EM force is due to these beasts, then every time we observe the EM force in the lab, it is an (indirect) observation of them. We have confidence in saying that a "real" photon exists because we see, for example, an excitation of an atom's electrons. We observe a change and say it counts as an observation of an energetic photon. If a charged particle causes another charged particle to change its momentum, how is that not the same situation. We see a change in momentum and attribute it to a "virtual" photon just like we see a change in (for example) an electron or atom's energy state and attribute that to a "real" photon. We didn't observe the "real" photon prior to seeing the change it made.
A photon is a quanta of the EM wave, and the EM wave carries force proven by experiment. So by definition a photon carries force.
Uhm...I think I've been about as clear as I can be that my question is not whether but how, which has been satisfactorily answered (I think) by the link I found...which corresponds to what Jeblack and Antiphon [I think] were saying.
@FireBones: No... virtual photons are a mathematical trick, they have and never HAVE had anything to do with a physical reality. They are useful in describing and calculating... that's it. We're not talking about pions here.
  • #31
If you found an answer to how a photon carries force in the direction it is traveling that would be very interesting as it would explain why charged particles attract/repel. The link you found is about virtual photons however.
  • #32
They may be a mathematical trick but the forces are quite real. The OP is wondering what (in the theory) transmits longitudinal force. I'm pretty sure it's the virtual photon.
Can anyone address the obvious questio: if virtual photons have no physical reality then isn't QED missing some major physical mechanism that it "fakes in" with the virtual photon?
  • #33
I imagine the fact photons have momentum and that a force is a variation in momentum doesn't help, is it? You want to know the mechanism. But you should have a model for the photon, and we don't have...
  • #34
...which do transmit the force!
http://hyperphysics.phy-astr.gsu.edu/hbase/forces/exchg.html#c1"
"[URL
http://en.wikipedia.org/wiki/Force_carrier
They transmit force. Are you suggesting force has nothing to do with physical reality?
  • #35
"[URL
But which is (I am just asking) the physical meaning of a particle (I'm talking of virtual particles of course) which energy E and momentum p don't obey E2 = (cp)2 + (mc2)2 ?
How much or to which extent can we believe in the physical existence of a matematical tool which is very useful in physics but cannot be directly measured? (Difficult question, I know)
