How does Bell make this step in his proof?
In summary, Bell's proof involves using mathematical induction to show that a statement is true for all natural numbers. He begins by proving the statement for the first natural number, and then uses the inductive hypothesis to prove it for the next natural number. This process is repeated until the statement is proven for all natural numbers, thus completing the proof. Bell's approach is a commonly used strategy in mathematical proofs and allows for a systematic and rigorous way of proving statements.
  • #36
N88 said:
Please: What is X?
We start here:
(1) ##-[A(\vec{a},\lambda)A(\vec{b},\lambda)-A(\vec{a},\lambda)A(\vec{c},\lambda)]##; under an integral.
IF X (a mathematical expression, explained in words; preferably something suggested by Einstein or EPR)
THEN (by Bell's equality):
(1) ##=## (2) ##=A(\vec{a},\lambda)A(\vec{b},\lambda)[A(\vec{b},\lambda)A(\vec{c},\lambda)-1]##; under an integral. QED.
Thank you.
[itex]X[/itex] is just algebra.
Once again:
Since [itex]A(\vec{b}, \lambda) = \pm 1[/itex], then [itex]A(\vec{b}, \lambda) A(\vec{b}, \lambda) = +1[/itex]. So we can write:
[itex]- (A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a},\lambda) A(\vec{c},\lambda)) = - (A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a},\lambda) A(\vec{b}, \lambda) A(\vec{b}, \lambda) A(\vec{c},\lambda))[/itex]
Now, we can factor out [itex]A(\vec{a},\lambda) A(\vec{b}, \lambda)[/itex]:
[itex]- (A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a},\lambda) A(\vec{c},\lambda)) = - A(\vec{a}, \lambda) A(\vec{b}, \lambda) (1 - A(\vec{b}, \lambda) A(\vec{c},\lambda))[/itex]
Likes zonde
  • #37
DrChinese said:
Just that a few will be perfectly correlated.
I'm sure this is obvious for QM experts, but could you maybe say a little about the "few"?
  • #38
Once again: Since
(D) [itex]A(\vec{b}, \lambda) = \pm 1[/itex], then [itex]A(\vec{b}, \lambda) A(\vec{b}, \lambda) = +1[/itex]. So we can write:
(E) [itex]- (A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a},\lambda) A(\vec{c},\lambda)) = - (A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a},\lambda) A(\vec{b}, \lambda) A(\vec{b}, \lambda) A(\vec{c},\lambda))[/itex]
(F) [itex]- (A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a},\lambda) A(\vec{c},\lambda)) = - A(\vec{a}, \lambda) A(\vec{b}, \lambda) (1 - A(\vec{b}, \lambda) A(\vec{c},\lambda))[/itex]
stevendaryl said:
So [itex]A(\vec{a}, \lambda)[/itex] and [itex]B(\vec{b}, \lambda)[/itex] are assumed to be ordinary functions of two parameters. His proof then just amounts to showing that there are no such functions reproducing the predictions of quantum mechanics.
In reasoning about [itex]A[/itex] and [itex]B[/itex], you can forget that they correspond to measurements, and just think of them as mathematical functions.
Here's the long answer: I see no connection with EPR. Though Bell claimed his formulation was connected to EPR, their idea was NOT this simplistic.
Here's the short answer: There are no such functions of two parameters in math or physics. But let's see if we can get around that dilemma.
I start with Thank You. It's my belief that you have reproduced Bell's argument (having been-there done-that myself); and it will be interesting to see if we can improve on it.
Accepting a solution by means of functions, then there must be three parameters, else they're not functions.
Say we assume [itex]A(\vec{a}, \lambda)[/itex] and [itex]B(\vec{b}, \lambda)[/itex] to be ordinary functions full-stop. Since a function cannot map the same inputs to two different values, you need to accept something like this: [itex]A(\vec{b}, \lambda+)= +1; A(\vec{b}, \lambda-)= -1[/itex].
So how do you now manage the physics of the problem? How do you ensure that, when you bring random [itex]A(\vec{b}, \lambda+)= +1[/itex] and random [itex]A(\vec{b}, \lambda-)= -1[/itex] together, their product is always one?
This earlier reply has a clue to the physical problem:
N88 said:
But in the second equation, the first ##A(\vec{b},\lambda)## was tested by Bob when Alice's detector was set to ##\vec{a}##. The second ##A(\vec{b},\lambda)## in the second equation can be tested by Bob when Alice's detector is at setting ##\vec{c}##. How does Bob come to have the same particles to test to get ##A(\vec{b},\lambda)^2=1##? Because doesn't that relation ##A(\vec{b},\lambda)^2=1## only hold for tests on the same λ?
Looks like there's another assumption somewhere?
So here's the new question, under the function-based analysis with [itex]A(\vec{b}, \lambda+)= +1; A(\vec{b}, \lambda-)= -1[/itex]:
How many [itex] \lambda[/itex]s in (E) need be identical, to allow the reduction to (F)?
  • #39
The claim made is that for a FIXED value of [itex]\lambda[/itex], it must be the case that
[itex]-(A(\vec{a}, \lambda) A(\vec{b}, \lambda) - A(\vec{a}, \lambda) A(\vec{c}, \lambda)) = A(\vec{a}, \lambda) A(\vec{b}, \lambda) (1 - A(\vec{a}, \lambda) A(\vec{c}, \lambda))[/itex]
That has been proved. You can ask: Why was Bell interested in proving this purely mathematical fact? Well, it was a step in proving the impossibility of a certain kind of hidden-variables theory that reproduced the predictions of quantum mechanics. But that particular step is pure mathematics.
  • #40
You don't multiply ##A(\vec{b}, \lambda+)## with ##A(\vec{b}, \lambda-)## that's the point. You multiply ##A(\vec{b}, \lambda_1)## with ##A(\vec{b}, \lambda_1)##
and ##A(\vec{b}, \lambda_2)## with ##A(\vec{b}, \lambda_2)## and so on. You never multiply ##A(\vec{b}, \lambda_1)## with ##A(\vec{b}, \lambda_3)##.
So if you object that this is possible you have to backtrack Bell's reasoning to the point where he introduces expression ##A(\vec{a}, \lambda)=\pm1##
  • #41
Yes, that's true. But we couldn't be sure about that without Bell and experiments.
  • #42
Where theta = 0 degrees, 90 degrees, 180 degrees, 270 degrees.
Likes dlgoff
  • #43
Many people do think Bell was not quite clear initially. For modern presentations, I like:
https://arxiv.org/abs/1503.06413
Causarum Investigatio and the Two Bell's Theorems of John Bell
Howard M. Wiseman, Eric G. Cavalcanti
https://arxiv.org/abs/1208.4119
The lesson of causal discovery algorithms for quantum correlations: Causal explanations of Bell-inequality violations require fine-tuning
Christopher J. Wood, Robert W. Spekkens
Bell was more concerned about classical reality, but a very important corollary of his theorem is that if there is no faster than light signalling, then a violation of Bell inequalities implies operational randomness. This development could, in principle, be used to certify that random numbers are truly random for any practical purpose:
https://arxiv.org/abs/0911.3427
Random Numbers Certified by Bell's Theorem
S. Pironio, A. Acin, S. Massar, A. Boyer de la Giroday, D. N. Matsukevich, P. Maunz, S. Olmschenk, D. Hayes, L. Luo, T. A. Manning, C. Monroe
  • #44
DrChinese said:
To deduce predetermination, we need perfect correlation for matching angles, whether measured or not.
We speak about model of reality not reality, right?
Now what it takes to claim that in particular model measurements of A and B are independent?
My answer is that it should be possible to split from the main model two independent submodels that take as an input something that represents two separate but entangled particles and separate measurement angle for each submodel.
  • #45
These guys, Hess/DeRaedt/Michelsen, say the major assumption in Bell's inequalities is counterfactual definitess
https://arxiv.org/pdf/1605.04889.pdf
"The major premise for the derivation of Bell’s inequality is
counterfactual definiteness, which in connection with Bell’s
use of setting variables restricts the domain of the variables
in the argument of Bell’s functions A to a subset NB of general
physical independent variables. NB does not include the
variables necessary to describe a general dynamics describing
many body interactions in the measurement equipment.
Using only the independent variables defined by NB, it is impossible
to find a violation of Bell’s inequality, which therefore
represents a demarcation between possible and impossible
experience [8], not between classical and quantum physics."
  • #46
Counterfactual definiteness (also known as "realism") is one of the two major assumptions in Bell's theorem, yes (the other being locality). Nothing particularly novel in that paper.
