How does the expansion of the universe work?
In summary: YouThank...YouIn summary, the universe is expanding and galaxies are getting further away from each other. The rate of expansion is the same for every point in the space.
EdColider
How does universe expansion work? I thought that the universe was infinite and the celestial corps were getting further distance from each other. If the universe is infinite, how does someone calculate something when infinity is getting bigger? From a reference point? Is the rate of expansion the same for every point in the space?
Likes DuckAmuck
Space news on Phys.org
It isn't getting bigger. Things are just getting further apart.
Imagine the two-dimensional number plane with a star at every point with integer coordinates. Then imagine that, starting at time 0, the stars start moving so that the coordinates at time t of the star with coordinates (a,b) at time 0 will be ((t+1)a,(t+1)b). Then the stars are all getting further away from one another, even though the extent is infinite.
By the way, that formula is not the one that describes the actual way that galaxies in our universe move apart. It is a much simpler, somewhat unrealistic, formula that is intended solely to help you visualise this kind of thing.
Likes TerrainAhead, Thewindyfan, bcrowell and 1 other person
EdColider said:
If the universe is infinite, how does someone calculate something infinite getting bigger? From a reference point? Is the rate of expansion the same for every point in the space?
When we talk about expansion we have to keep in mind that we are talking about how physical objects (and light) behave. What universal expansion means is that galaxies and galaxy clusters which are not bound strongly enough to each other through gravity will recede from each other over time. In other words, the distance between these unbound galaxy clusters will increase over time. This increase in distance follows a set of rules that can be naively described as an 'expansion' similar to how objects attached to a rubber band recede from each other as the rubber band is stretched (or a rubber sheet if you want to talk about expansion in 2 dimensions).
I want to emphasize that expansion is about the increasing distance between objects, not about space literally stretching like a rubber sheet. The rubber sheet is simply an analogy.
Likes shadishacker, Thewindyfan and EdColider
Thank You
Thank You
@EdColider If you think infinity can't get bigger, google "Hilbert's Hotel".
Cool. I've never heard about it before.
I understand that we can always add 1 more item to a list.
What I can't understand is how does someone calculate the variation of something infinity.
Your question is not clear. Do you mean "how much bigger does it get" ? If so, it is not a meaningful question, or put another way, it does not have a meaningful answer. Or, put another way, infinity plus 1 is exactly the same size as infinity so you can say it doesn't get any bigger at all.
Likes EdColider
Thank You
Sorry for the meaningful question. You really helped me out. :D
Look back at my post. Cosmologists don't typically deal with infinity, they deal with finite numbers, such as the distance between galaxies.
Likes EdColider
Note that in the case of the expanding universe, the stars are not actually moving. They are getting further apart due to the expansion of space. Compare with two ants holding on to a rubber band being stretched out.
"Moving" is relative. They are not moving relative to standard FRW coordinates, but they are moving relative to each other.
We should probably be careful about how we use the term "expansion of space", since in other threads people are being told that the inferences they are drawing from that phrase are wrong. :wink:
Likes ElijahRockers
Obviously, but you know as well as I do that when no frame is specified in cosmology, we are usually referring to the comoving coordinates and I believe this is the standard assumption students will make if not told otherwise.
So what would you use instead in this case? It is what it is in comoving coordinates with cosmological time as the simultaneity convention. I think starting to get into these issues in an I thread is pulling it a bit too far.
Yes, I agree. But I'm still not sure that saying distant stars/galaxies are "not moving", meaning not moving relative to these coordinates, will avoid confusion. See below.
I would say that objects (or comoving objects if more precision is needed) are getting further apart (basically how andrewkirk started post #2). But that does imply that they are moving--saying they are "not moving", to me, implies that they are not getting further apart, which is why I think using the term "not moving" in this connection is likely to cause confusion.
Thats funny, I have the exact opposite experience, ie, that calling things "moving" is a source of widespread confusion such as ascribing cosmological redshift to the Doppler effect. Also, I think moving seems to imply changing spatial coordinates with time more than increasing distance.
Of course, it may be better to avoid using the word "moving" at all.
Likes xAxis
I'm with you here. In co-moving coordinates, the only 'movement' will be peculiar movement. Cosmological redshift is then due to metric expansion, but the peculiar movement may have a Doppler effect that changes the observed redshift marginally.
That would be my preference, yes. Unless a spacetime is stationary, there is no way to construct a coordinate chart such that things are "moving" in one sense (nonzero coordinate velocity) iff they are moving in the other sense (nonzero observed redshift/blueshift of light signals between objects). And as soon as these two senses of "moving" are uncoupled, you have the potential for confusion, since our intuition says they should be coupled (more precisely, that we should always be able to choose coordinates so that they are coupled).
The problem is that it's really hard to describe, say, the properties of the FRW cosmological models in ordinary language without using the words "moving" or "expansion". We can do it with math, of course, but then we have to explain the physical meaning of the math, and again, that's really hard to do without using those two words.
FWIW (my two cents) in the past I have said things like:
"Hubble law distance expansion is not like ordinary motion in the sense that nobody gets anywhere by it, everybody just becomes farther apart".
Nobody approaches a goal or destination by it, relative positions don't change, all the distances just increase by a fixed percentage per unit time.
It's like dots on an expanding sphere each staying fixed at the same latitude and longitude---not moving around in the ordinary sense but becoming farther apart.
This is allowed by spacetime curvature, the unintuitive thing at the heart of GR. GR says you have no right to expect distances NOT to change between relatively stationary objects---objects each of which is not moving in the space around it.
Langauge like that might or might not help newcomers.
For me, what I find most confusing when trying to understand expansion is all the different interpretations of 'expansion'. For example, just what is expanding? Space?, Dark Energy?, Quantum fluctuation?, Something else? Just that fundamental question seems to cause a lot of confusion. It'd be great if someone could clear that one up.
Also, quite often people will say that it is the 'space' in-between galaxies that is 'growing' which 'pushes' the galaxies apart. For me personally, that is confusing, as just what it is that is 'growing'? How can 'space' physically exert a force on such massive bodies as clusters of galaxies in such a way to 'push' them apart?
My simple way of looking at this (which I accept might not be correct) is when we talk about 'expansion' we are really talking about matter (galaxies etc) that aren't bound by gravity, moving apart. The process that drives this is the vacuum energy (Dark Energy), which is a field that permeates all 'space'.
What I still get confused about is if the vacuum energy is 'expanding' or it is already present (from the initial inflation prior to re-heating) or if galaxies where the gravitational pull isn't strong enough to keep them together move apart because our universe is curved (like a sphere) and they are just 'falling' due to this curvature.
Anyway, just my 2 cents. :)
The universe would have been expanding today even if there was no evidence of dark energy - just expanding at a lesser rate. So no, dark energy is not the reason for expansion.
Here are two charts, both for flat space expansion.
1) expansion with dark energy:
'a' is the scale factor and 'V_gen' is the recession rate of a galaxy that is presently at the Hubble radius (a 'generic recession rate').
2) Expansion without dark energy:
You can see that the two charts start off much the same, with 'decelerating expansion' and chart 1 shows late 'accelerating expansion', which we believe is caused by dark energy.
All that we can say with some certainty is that the universe presently expands because it expanded in the past. Exactly what started the expansion is not certain, because there are multiple theories and no conclusive evidence for anyone theory.
Just for clarification, could you tell me which theory predicts expansion without dark energy?
Expansion is part of any cosmological model based on the FRW metric in GR. The energy content of the universe then affects exactly how the expansion proceeds. Dark energy is only required for accelerated expansion.
ΛCDM with Λ=0. With the values we measure today, Λ played a negligible role for the first few billion years, but for the last 5 billion years it is dominating the expansion dynamics. I presume that you understand how the expansion equations work?
I sort of have a basic layman's understanding from things I have read and watched. In particular Leonard Susskind's lectures on cosmology, as well as a various other things. So my knowledge is very basic.
As I understand it, GR doesn't predict expansion, it predicts the universe will contract under gravity. The cosmological constant (Lambda) was added to keep the universe static. So if it is adjusted to >0, then the model describes an expanding universe sure. But it is just a model that describes how the universe is expanding, not what caused expansion in the first place.
Again, from my limited understanding, I thought the universe initially expanded very rapidly prior to the big bang, (Inflation) due to the vacuum energy being many orders of magnitudes bigger than it is today. So this caused to universe to double in size about every 10^-32 seconds. When the vacuum energy suddenly collapsed, matter was formed and the universe heated up very rapidly (which I understand is the big bang) and the energy density dropped to be somewhere near the value it is today. So in orders of magnitude, the universe is about the same size as it was just after the initial inflation, doubling in size about every 10 billion years.
Now as I understand it, Dark Energy, Vacuum Energy, Cosmological Constant... they are all the same thing. So it is the same 'energy' that was responsible for inflation that is now responsible for the acceleration of the universe. So we couldn't have this acceleration without 'Dark Energy' (Vacuum energy)
Hence why I asked what theory of expansion there was without dark energy, because without dark energy there would have been no expansion at all.
No, GR predicts that the cosmos must either expand or contract - it can never be static for a length of time. The cosmological constant cannot make it stably static anyway. Einstein did attempt that by adjusting the value of Lambda, but it is easy to prove that such a state is not stable and would have quickly tipped over to either contraction or expansion.
I'm not too knowledgeable on inflation, because it is not part of the ΛCDM cosmological model, but AFAIK, inflation is not driven by 'dark energy'. There are many possible sources under investigation. The other fact that you seem to have missed is that 'dark energy', 'vacuum energy' and the 'cosmological constant' are not equivalent. I'm short on time at the moment, so please google the terms and see if you can understand the differences.
No, without dark energy there would not be accelerated expansion today. But there can be expansion without accelerated expansion. They're not the same thing.
Yes, sure. Sorry I didn't explain myself properly. I understand the cosmological constant is a parameter in GR, Dark energy is referred to as responsible for the accelerating rate of expansion and Vacuum energy is implied to exist through quantum field theory. So in that respect they are not exactly the same but they all refer to some 'energy' that has an effect on expansion.
I know Vacuum energy is thought to be too many orders of magnitude bigger for it to be responsible for dark energy, but there is still some 'energy' that permeates all of space. The part that seems to confuse me is if the energy responsible for accelerating expansion the same energy that was responsible for Inflation? It must have present since before the big bang. By the way, as I understand it, the big bang is not responsible for the early expansion, that came from inflation.
Again, I am confused about how there could be expansion without dark energy? If you have time, could you explain that please. (In English please, I don't speak Math very well! :D)
No, it is not the same. What caused inflation must have been much denser than today's dark energy. It must then have disappeared due to some sort of dynamics, which we can only speculate about. Although dynamic, it would have several properties in common with dark energy and it is entirely possible that whatever dark energy is also exhibits dynamical properties.
This is similar to asking "can you explain the color blue? I am blind". If you are not willing to learn the math, you will essentially have to take it on faith from those who do know it. It is similar to the fact that if you throw something up, it can have a velocity in the up direction even thouh the gravitational force pulls it down.
  • #31
Expansion now is simply a continuation of the original expansion (not inflation which is different as Orodruin has pointed out). Dark Energy causes the ACCELERATION of that expansion, as Peter has already pointed out.
I suggest you read the article linked to in my signature. I explain about inflation/expansion/acceleration-of-expansion.
  • #32
In my opinion, the 'Big Bang' as it is used today is simply a catch-all for whatever preceded the present expansion dynamics (which proceeds according to the Friedmann solution to the GR equations). It could have been 'standard inflation', or a type of bounce, or even a relatively smooth, but dense transition from an earlier contraction phase, without a 'Bang'. Nobody quite knows, but it is the subject of intense study and observation.
BTW, 'dark energy' could conceivably be just the cosmological constant, interpreted as a constant inherent spacetime curvature that was left over after inflation (or whatever condition started the later expansion phase). It is still the simplest interpretation that seems to fit the bulk of observational data. There are some areas of so-called "tension" between data and the constant Lambda, but it is also the subject of intense study.
Likes marcus
  • #33
Ah, ok, thanks. I think I must of misunderstood some of the lectures on this bit, as it seemed to imply dark energy was part of the left over energy that caused inflation. But I'll go through it again.
Yes of course, I understand I'd have to take things on faith without learning the math, which is fine. And I do try and learn what I can. But If I want to work in a foreign country then yes I'd need to learn the language but if I just want to find out more about it, then English is often good enough :D
Original expansion? What caused the original expansion? It seems like you are implying that there was inflation, then the universe stopped growing, then expansion started? Could you clarify what you mean please.
Ok, thanks. That is sort of how I understood it. I guess I just concluded at some point that expansion was linked to inflation, so were part of the same thing.
In the Leonard Susskind lectors he often refers to Dark energy and the cosmological constant as being the same thing.
  • #34
I can't even remotely see how you infer that from what I said. Where did I even come close to implying that there was ever any stopping in the expansion? For the causes of the original expansion/inflation you'll have to ask someone else. All I'm saying is that the universe was expanding from the beginning and it has never stopped. Without Dark Energy, it was expected, up until the late 1990's, to eventually slow down, reverse, and end in a big crunch. Dark Energy had nothing to do with the original expansion.and still doesn't, but it has everything to do with why the Big Crunch concept has been abandoned by mainstream cosmology.
  • #35
When I first studied modern cosmology (around Y2K), I made the following plot in an attempt to understand the "whole of expansion". I used 'r' to depict the radius evolution of the presently observable universe, with rP and tP the Planck radius and time respectively.
It is more or less correct for the simplest form of inflation, where Lambda was at a constant large value until end of inflation. Thereafter it is radiation dominated until ~105 years, matter dominated until ~1010 years and thereafter Lambda dominated.
This is not unlike the nice 'trumpet' expansion pictures we often see in articles.
