How far can a motor be overloaded?
  • Thread starter kyaw min
  • Tags
    Motor
In summary, the calculation says that we need a 40kW 3 phase AC asychorne motor. If we use a 37kW AC motor instead, we need to take precautions like adding a 5% safety factor to the calculations.
kyaw min
According to the caculation, we need a 40kW 3 phase AC asychorne motor. Could we use 37kW AC motor instead of 40kW? If yes, what kind of precautions have to be taken?
thanks
I don't know what kind of calculations you did, but are you sure you didn't understimate the power requirement?
If you ignored things like friction and people holding it with their fingers then you might prefer something higher than 40 kW instead?
Most motors have a service factor of 1.15, meaning they can be run for shot durations at 115% of nameplate rating. But as CompuChip suggested, you're not giving yourself any safety factor and you really should ask yourself just how confident you are in your calcs and whether the peace of mind and assurance of lifespan of having a properly sized motor is worth the extra 5% cost.
Put another way, the cost difference between the two motors is equivalent to the cost of the first four days of running the motor (assuming it runs 24 hrs a day). So is it really worth it to skimp?
Service factor (SF) is an indication of how much overload a motor can withstand when operating normally within the correct voltage tolerances. For example, the standard SF for open drip-proof (ODP) motors is 1.15. This means that a 10-hp motor with a 1.15 SF could provide 11.5 hp when required for short-term use. Some fractional horsepower motors have higher service factors, such as 1.25, 1.35, and even 1.50. In general, it's not a good practice to size motors to operate continuously above rated load in the service factor area. Motors may not provide adequate starting and pull-out torques, and incorrect starter/overload sizing is possible.
Traditionally, totally enclosed fan cooled (TEFC) motors had an SF of 1.0, but most manufacturers now offer TEFC motors with service factors of 1.15, the same as on ODP motors. Most hazardous location motors are made with an SF of 1.0, but some specialized units are available for Class I applications with a service factor of 1.15.
Creative thinking is breezy, Then think about your surrounding things and other thought products. http://electrical-riddles.com
FAQ: How far can a motor be overloaded?
What is motor overload?
Motor overload is a condition in which the motor is required to produce more torque and power than it is designed to handle. This can be caused by excessive load, voltage fluctuations, or other external factors.
How do I know if my motor is being overloaded?
There are several signs that your motor may be overloaded, including excessive noise, vibration, and heat. You may also notice a decrease in performance or an increase in energy consumption. It is important to regularly monitor your motor's performance and address any signs of overload.
What are the consequences of motor overload?
The consequences of motor overload can vary depending on the severity and duration of the overload. In the short term, it can cause damage to the motor, such as overheating or burning out. In the long term, it can reduce the lifespan of the motor and lead to more frequent maintenance and replacement costs.
How far can a motor be overloaded before it becomes dangerous?
The safe overload limit for a motor is typically around 10-15% above its rated capacity. However, this can vary depending on the specific motor and its application. It is important to consult with the manufacturer or a qualified engineer to determine the safe overload limit for your motor.
How can I prevent motor overload?
To prevent motor overload, it is important to properly size the motor for its intended application and monitor its performance regularly. Proper maintenance and avoiding excessive loads or voltage fluctuations can also help prevent overload. It is also recommended to use overload protection devices, such as fuses or circuit breakers, to protect the motor from damage.
