nenyan
- 67
How to convert red shift to parsecs? Is there a simple converting equation?
nenyan said:How to convert red shift to parsecs?
nenyan said:s there a simple converting equation?
George Jones said:This depends on which concept of distance is used. See the first paragraph of the attached file.
I wrote up an answer for someone else, who specified z = 0.4. I didn't use dimensionless parameters. See the last two graphs in the attached file.
Redshift is a measure of the expansion of the universe and is directly related to distance. The higher the redshift value, the farther the object is from us. This means that the distance in parsecs increases as the redshift value increases.
The formula for converting redshift to distance in parsecs is: distance (in parsecs) = (speed of light * redshift value) / Hubble constant. The Hubble constant is a value that represents the rate of expansion of the universe.
The redshift of an object is measured by observing its spectrum. The spectrum of a distant object will have a redshifted pattern, which can be compared to the spectrum of a stationary object to determine the redshift value.
A redshift value of z=1 means that the object is located at a distance of approximately 3.26 billion parsecs from Earth. This distance is equivalent to 10.6 billion light years.
Redshift values can be negative if the object is moving towards us, which is known as a blueshift. A negative redshift value indicates that the object is located closer to us than its rest frame. The distance in parsecs for a negative redshift value will be smaller than the distance for a positive redshift value.
