How many solutions for this general equation?
  • MHB
  • Thread starter poissonspot
  • Tags
    General
In summary, there are 3 solutions for even n and 2 solutions for odd n when solving the equation $x^n=n^x$ for positive x. This can be verified by rewriting the equation and using the derivative to find the maximum point. For negative x, there may be 1 solution for even n and no solutions for odd n.
poissonspot
40
I was wondering if there is any way to know in general how many real solutions $x^n=n^x$ may have with n being a positive integer. Thanks!
Using IVT one can see that if n is even there must be at least three solutions, and if n is odd there exists at least two. But are these the "sharpest" bounds?
Mathematics news on Phys.org
Hi conscipost! :)
For even n, there are exactly 3 solutions, and for odd n there are exactly 2.This can be verified by rewriting your equation for positive x:
\begin{array}{lcl}
x^n&=&n^x \\
\ln(x^n)&=&\ln(n^x) \\
n \ln x &=& x \ln n \\
\frac{\ln x}{x} &=& \frac{\ln n}{n}
\end{array}
The derivative of \(\displaystyle \frac{\ln x}{x}\) is \(\displaystyle \frac{1 - \ln x}{x^2}\) which has exactly 1 root for $x=e$.
This means that \(\displaystyle \frac{\ln x}{x}\) has a maximum at $x=e$.
See this plot to see what it looks like.
Since we have a solution at $x=n$, there must be exactly 1 other solution at the other side of $x=e$ (for positive x).
For negative x with odd n there can be no solution, since $x^n$ is negative while $n^x$ is positive.
For negative x with even n there is exactly 1 solution, since $x^n$ is strictly decreasing, while $n^x$ is strictly increasing.
So for even n, there are exactly 3 solutions, and for odd n there are exactly 2.
FAQ: How many solutions for this general equation?
What is a general equation?
A general equation is a mathematical statement that represents a relationship between variables using symbols and operations.
What is the purpose of finding solutions for a general equation?
The purpose of finding solutions for a general equation is to determine the values of the variables that make the equation true. This can help in solving real-life problems and understanding mathematical concepts.
How do you determine the number of solutions for a general equation?
The number of solutions for a general equation can be determined by analyzing the degree and type of the equation, such as linear, quadratic, or exponential. The number of solutions can also be determined by graphing the equation and observing the number of intersections with the x-axis.
What are some common methods for solving general equations?
Some common methods for solving general equations include substitution, elimination, and graphing. Other methods include factoring, completing the square, and using the quadratic formula.
Can a general equation have more than one solution?
Yes, a general equation can have more than one solution. This is known as a system of equations, where multiple equations are solved simultaneously to find the values of the variables. In some cases, a general equation may also have an infinite number of solutions, such as in the case of parallel lines.
