How to calculate the horizontal shift?
In summary, the conversation discusses the concept of horizontal shift and its relation to calculating the horizontal component of a_cx. It is mentioned that a_{cx} is in terms of the angle and radius of the Earth, but to include the 50 m vertical distance, a_{cy} may also need to be considered to calculate the net acceleration. The conversation also clarifies that there is a centrifugal force, not a centripetal force, due to the rotation of the Earth. Finally, the conversation discusses the displacement formula and clarifies that the final position is not equal to ##\frac{1}{2} a_{cx}t^2##, but rather the horizontal displacement is how far an object lands from where it would
centinela20
I have a homework problem where we consider a point over the earth's surface, which is in a different parallel to the equator. There is a centrifugal force due to the rotation of the earth. (there is an attached figure of this).
I need to calculate the horizontal shift due to a_{cx} of an object falls vertically from 50 m above this point.
a_{cy} = \omega^2 R \cos{\theta}^{2} and
a_{cx} =\omega^2 R \sin{\theta} \cos{\theta}
I don't understand what horizontal shift means. I believe that means calculate the horizontal component of a_cx. But when I do that a_{cx} is in terms only of the angle and the radius of the earth. But what I need is to include the 50 m vertical distance, so I think that maybe we need to use a_{cy} too and calculate the net acceleration acting at this point. But I don't really know. I am pretty lost.
I would take it as meaning displacement, hence the need to specify the height.
Btw, you do not mean "There is a centripetal force due to the rotation of the earth." In the rotating frame there is a centrifugal force. Centripetal force is usually considered in an inertial frame, but it is not an applied force; it is the radial component of the net of the applied forces.
Likes centinela20
Yes, sorry that was a typo mistake.
So if I take it as a displacement it would be ##\triangle x = p_{final} - p_{initial} ##
and the initial postition is the 50 m,
is the final position ## x= \frac{1}{2} a_{cx}t^2## ?
No, horizontal displacement, i.e. how far it lands from where it would have landed if not for Earth's rotation.
Likes centinela20
Related to How to calculate the horizontal shift?
1. What is the formula for calculating horizontal shift?
The formula for calculating horizontal shift is h = -c/b, where h represents the horizontal shift, c represents the constant term, and b represents the coefficient of the x-term.
2. What does the horizontal shift represent?
The horizontal shift represents the amount by which a graph is shifted left or right from its original position on the x-axis. A positive horizontal shift indicates a shift to the right, while a negative horizontal shift indicates a shift to the left.
3. How do I determine the values of c and b in the formula?
The value of c can be determined by looking at the constant term in the equation. The value of b can be determined by looking at the coefficient of the x-term. For example, in the equation y = 2x + 3, c = 3 and b = 2.
4. Can a horizontal shift be negative?
Yes, a horizontal shift can be negative. This indicates that the graph has been shifted to the left by the specified amount.
5. How do I graph an equation with a horizontal shift?
To graph an equation with a horizontal shift, start by plotting the original points on the graph. Then, use the calculated horizontal shift value to shift the points left or right on the x-axis. Finally, connect the shifted points to create the shifted graph.
